Question regarding the equivalence principle
In summary: This is due to the fact that the apparent length is a vector quantity, and the velocity vector (the direction and magnitude of the acceleration) is always pointing downwards.
AdvaitDhingra
51
Hello,
So I read that a person in a rocket accelerating at 9.8m/s^2 would feel the same pull downwards as a person standing on the Earth's surface.
However, I can think of a few instances where you could tell the difference:
- If you measure g (9.8N/kg) on Earth, you will notice that the value decreases as you go up. On the rocket in remains constant.
- If you have a charged particle, wouldn't a moving rocket make it emit electromagnetic radiation?
AdvaitDhingra said:
Hello,
First, the equivalence principle explicitly talks about local experiments. There is certainly no equivalence to an outside observer of someone on the surface of the Earth and someone accelerating through space.
More to the point, of course constant acceleration is not equivalent to a time-varying gravitational field.
The question about EM radiation is more subtle. If you have a charged particle in the two cases, then it's not going to change over time. In fact, the equivalence principle tells you that the local EM field must be the same in both cases, as measured locally.
If you have an observer outside the rocket, then as before the two situations are not (to them) equivalent. The EM field they measure due to the charged particle may well be different in the two cases.
Likes vanhees71, AdvaitDhingra and Ibix
Actually, the locally measured acceleration decreases up the rocket. If the acceleration were the same the rocket's length would not change viewed from an inertial frame - i.e. it would not length contract.
Understanding this is the key to resolving Bell's spaceships paradox.
Likes vanhees71 and AdvaitDhingra
As @PeroK mentioned the equivalence principle is a local principle. In other words, it is valid only over distances and times small enough that the curvature of spacetime is negligible. This corresponds to an absence of tidal gravity.
In relativity a uniformly accelerating reference frame in flat spacetime is called Rindler coordinates. Due to time dilation, hovering observers higher up have lower proper acceleration than observers lower down. So even in flat spacetime the value decreases as you go up in the rocket. This effect can actually be used to derive gravitational time dilation over small distances, e.g. in the Pound-Rebka experiment.
However, on Earth, due to tidal effects (curved spacetime), this effect is more pronounced. The acceleration of a hovering observer decreases faster around the Earth than in flat spacetime. This effect is real and can really distinguish between the two, but it is explicitly excluded by the equivalence principle. Where tidal effects are measurable the equivalence principle does not apply.
Ahh thank you. I was always confused what "local" meant.
Likes vanhees71 and Dale
If you've studied a bit of SR then you may notice a interesting subtlety regarding a "uniformly accelerating" rocket. Let's analyse the rocket from its original rest frame:
If every part of the rocket has identical acceleration (starts to accelerate simultaneously and always has the same velocity - as measured in the original rest frame), then there is clearly no length contraction. The head and tail of the rocket must, by a simple application of kinematic formulae, remain the same distance apart.
This means that from the rocket's perspective it must be stretching! I.e. it's proper length must be increasing.
(To see this just imagine that the accceleration stops at some point. Externally, the rocket still has its original proper length, but as it's now traveling at some non-zero speed, it ought to be length contracted.)
And, if from the rocket's perspective it remains rigid (i.e. retains its original rest length), then the different parts of the rocket must have (slightly) different accelerations as measured externally. As the rocket is slowly length contracting in the orignal rest frame.
You can formalise all this using Rindler coordinates, as above, but it's a good example where you must be careful with seemingly simple assumptions when dealing with relativistic motion.
FAQ: Question regarding the equivalence principle
What is the equivalence principle?
The equivalence principle is a fundamental concept in physics that states that the effects of gravity are indistinguishable from the effects of acceleration. This means that an observer in a closed laboratory cannot tell the difference between being in a gravitational field and being in an accelerating reference frame.
Who first proposed the equivalence principle?
The equivalence principle was first proposed by Albert Einstein in his theory of general relativity in 1915. However, the concept has been explored by other scientists, such as Galileo and Newton, in different forms throughout history.
How does the equivalence principle relate to the bending of light by gravity?
According to the equivalence principle, the path of a light ray should be bent in the same way by a gravitational field as it would be by an accelerating reference frame. This was confirmed by observations during a solar eclipse in 1919, providing evidence for Einstein's theory of general relativity.
What are the implications of the equivalence principle?
The equivalence principle has significant implications for our understanding of gravity and the behavior of objects in the universe. It is the basis for Einstein's theory of general relativity, which has been crucial in explaining various phenomena, such as the bending of light, the formation of black holes, and the expansion of the universe.
Is the equivalence principle still a debated concept?
While the equivalence principle is widely accepted in the scientific community, there are still ongoing debates and discussions about its exact implications and applications. Some scientists are exploring ways to test the limits of the principle, while others are using it to develop new theories and models for understanding the universe.
