Question Related to Newton's Laws of Motion
In summary: Can you calculate it using the mass of the rocket and the acceleration due to gravity?In summary, the fully loaded Saturn V rocket has a mass of 2.92 x 10^6 kg and its engines have a thrust of 3.34 x 10^7 N. The downward force of gravity on the rocket at blast-off is equal to the weight due to gravity, which can be calculated using the mass of the rocket and the acceleration due to gravity. The unbalanced force on the rocket at blast-off is the difference between the thrust and the downward force of gravity. The acceleration of the rocket as it leaves the launching pad depends on the net force acting on it, which is equal to the thrust minus the weight due to
NeomiXD
31
1. A fully loaded Saturn V rocket has a mass of 2.92 x 10^6 kg. Its engines have a thrust of 3.34 x 10^7 N.
a. What is the downward force of gravity on the rocket at blast-off?
b. What is the unbalanced force on the rocket at blast-off?
c. What is the acceleration of the rocket as it leaves the launching pad?
Given:
m = 2.92 x 10^6 kg
F= 3.34 x 10^7 N
Required:
a. F?
b. F?
c. a
Solution:
how do you solve this question? Or can someone explain it in more detail. Also, when it says "Its engines have a thrust of 3.34 x 10^7 N" does the value represent the force applied upward?
Given:
m = 2.92 x 10^6 kg
F= 3.34 x 10^7 N
Required:
a. F?
b. F?
c. a
Solution:
Yes. That's the upward force. The downward force is just the weight due to gravity. What is the acceleration due to gravity g = _____ and how can you use that number with the mass of the rocket to get the force due to gravity?
Yes the thrust is the upward force. What is the downward force acting on the rocket? (This is what they are asking you in part a).
Related to Question Related to Newton's Laws of Motion
1. How many laws of motion did Newton develop?
Newton developed three laws of motion, also known as Newton's laws of motion.
2. What is Newton's first law of motion?
Newton's first law of motion, also known as the law of inertia, states that an object at rest will remain at rest and an object in motion will remain in motion at a constant velocity unless acted upon by an external force.
3. What is Newton's second law of motion?
Newton's second law of motion states that the force exerted on an object is equal to its mass multiplied by its acceleration. This can be expressed as F=ma, where F is force, m is mass, and a is acceleration.
4. What is Newton's third law of motion?
Newton's third law of motion states that for every action, there is an equal and opposite reaction. This means that when one object exerts a force on another object, the second object will exert an equal and opposite force back on the first object.
5. How do Newton's laws of motion apply to everyday life?
Newton's laws of motion can be seen in many everyday activities, such as driving a car, throwing a ball, or riding a bike. They also play a crucial role in understanding the behavior of objects in motion, including the movement of planets and satellites in space.
