MHB Question via email about complex numbers
The discussion focuses on mapping the region defined by |z| ≥ 5 under the transformation w = z^2. It establishes that any complex number can be expressed in polar form, leading to the conclusion that if |z| = r ≥ 5, then |z^2| = r^2 ≥ 25. Consequently, the image of the region under the mapping w = z^2 is everything on or outside the circle defined by |w| ≥ 25. However, a correction is noted that the radius should be interpreted as 5, not 25, leading to a circle of radius 5. The final graphical representation emphasizes the correct shading of the required region.
Prove It
MHB
Plot the image of the region $\displaystyle \begin{align*} \left| z \right| \geq 5 \end{align*}$ under the mapping $\displaystyle \begin{align*} w = z^2 \end{align*}$.
We should note that we can write any complex number as $\displaystyle \begin{align*} z = r\,\mathrm{e}^{\mathrm{i}\,\theta} \end{align*}$ where $\displaystyle \begin{align*} r = \left| z \right| \end{align*}$ and $\displaystyle \begin{align*} \theta = \textrm{arg}\,\left( z \right) + 2\,\pi\,n , \,\, n \in \mathbf{Z} \end{align*}$. So that means
$\displaystyle \begin{align*} z &= r\,\mathrm{e}^{\mathrm{i}\,\theta} \\ \\ z^2 &= \left( r\, \mathrm{e}^{\mathrm{i}\,\theta} \right) ^2 \\ &= r^2\,\mathrm{e}^{2\,\mathrm{i}\,\theta} \end{align*}$
thus if $\displaystyle \begin{align*} \left| z \right| = r \geq 5 \end{align*}$ then that means $\displaystyle \begin{align*} \left| z^2 \right| = r^2 \geq 25 \end{align*}$. Since $\displaystyle \begin{align*} \theta \end{align*}$ can take on any value, that means that $\displaystyle \begin{align*} 2\,\theta \end{align*}$ also can, and thus the region defined by $\displaystyle \begin{align*} w = z^2 \end{align*}$ must be everything on or outside of the circle defined by $\displaystyle \begin{align*} \left| z^2 \right| \geq 25 \end{align*}$, so in other words, everything on or outside the circle centred at the origin of radius 25 units.
So graphically we have (using the standard convention of shading the region that is not required)...
Mathematics news on Phys.org
Essentially correct except that 25 is the radius squared. So make it a circle radius 5.
Likes Greg Bernhardt
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
