wofsy
- 726
Suppose I have two embeddings of the circle into the 3 sphere. Is S3-minus the first image diffeomorphic to S3 - the image of the second?
zhentil said:Look at an unknot and a trefoil knot and compare the fundamental group of the complement.
zhentil said:If I'm getting this right, the fundamental group of the complement of a non-trivial knot should be a bouquet of circles-type situation; i.e. you have some generators with some anti-commutation relations, and the commutator kills all of it.
Diffeomorphism is a mathematical concept that refers to a smooth and invertible map between two differentiable manifolds. In simpler terms, it is a transformation that preserves the smoothness and structure of a mathematical object.
To determine if two spaces are diffeomorphic, you need to show that there exists a diffeomorphism between them. This can be done by finding a smooth map between the two spaces that is one-to-one, onto, and has a smooth inverse.
Diffeomorphism is a fundamental concept in mathematics as it allows us to study and understand geometric and topological properties of spaces. It also plays a crucial role in various areas of mathematics, such as differential geometry, topology, and dynamical systems.
Yes, two spaces can have different shapes and still be diffeomorphic. The concept of diffeomorphism is concerned with the smoothness and structure of a space, rather than its specific shape or size.
No, diffeomorphic spaces are not always homeomorphic. Homeomorphism is a weaker condition than diffeomorphism, as it only requires a continuous map between two spaces, while diffeomorphism requires a smooth map. Therefore, it is possible for two spaces to be diffeomorphic but not homeomorphic.
