Questions about a Piezo igniter
  • Thread starter Fischer777
  • Tags
    Piezo
In summary, the conversation discusses the reliability of piezo igniters and the factors that may affect their performance, such as altitude. There is also a mention of a test conducted on a piezo igniter, which showed that the mechanics of the device gave out after 111,000 strikes, rather than the quartz crystal. The question about the terminals and current produced by a piezo igniter is left unanswered.
Fischer777
89
Questions about a Piezo igniter...
About how many times can one strike a piezo igniter before it wears out, or before it's electrical output is severely reduced?
hi there
if the constant deformation of the quartz crystal as its struck doesn't physically damage the crystal ... ie crack/shatter it, then I have no reason to believe that it would ever fail to produce a spark.
it is interesting to note tho (wiki...) that piezo igniters become unreliable at altitude...significantly so at >8000ft.
here's a page where a guy set up a test jig to test a piezo igniter. firing it 25 times a minute, at 111,000 strikes it was the mechanics that gave up, not the quartz crystal!
http://www.gswagner.com/piezo/piezo.html
cheers
Dave
Also, does a piezo lighter/igniter have a distinct 'positive' and 'negative' terminals, or does it create and rapid 'alternating current' (a strong negative voltage followed by an equally strong positive voltage)?
I can't answer that, maybe one of the guru's can. I haven't personally seen anything in print.
Dave
Related to Questions about a Piezo igniter
1. How does a Piezo igniter work?
A Piezo igniter works by converting mechanical energy (such as pushing a button or turning a knob) into electrical energy. This electrical energy is then used to create a spark, which can ignite a gas burner or other fuel source.
2. What are the advantages of using a Piezo igniter?
Piezo igniters are a popular choice for their reliability and ease of use. They require no external power source, are relatively inexpensive, and can be used in a wide range of applications such as gas stoves, ovens, and grills.
3. Can a Piezo igniter be replaced if it stops working?
Yes, Piezo igniters can be replaced if they stop working. However, it is important to properly diagnose the issue first to ensure that the igniter is the problem. If it is determined that the igniter needs to be replaced, it can usually be easily done with basic tools and minimal technical knowledge.
4. How long do Piezo igniters typically last?
The lifespan of a Piezo igniter can vary depending on usage and maintenance. On average, they can last anywhere from 2-5 years. However, with proper care and regular cleaning, they can last even longer.
5. Are there any safety precautions to keep in mind when using a Piezo igniter?
Yes, it is important to always follow the manufacturer's instructions and safety guidelines when using a Piezo igniter. This may include keeping the igniter clean and free of debris, ensuring it is properly connected to the fuel source, and using caution when handling the igniter or any nearby flammable materials.
