Questions about accelerated frames of reference
In summary, acceleration is not frame dependent, and you can measure it within your frame without looking at another one.
velixo
Suppose we have two frames of reference, with one being accelerated (not inertial). This could be you standing on the platform of a train station as a train in front of you is starting. From the train's point of view, you are accelerating, but one obviously knows that it is actually the train that is accelerating, because you feel no force (acceleration) being applied to you.
However, if we have two reference frames where we are not a part of either of them, but instead we are merely observing/measuring them, how do we know which one is the non-inertial one?
Thanks for any replies in advance.
You can measure the proper acceleration of your frame with an accelerometer. Then you can determine the proper acceleration of other frames based on their coordinate acceleration relative to you frame.
I'm probably not being fully clear :P I'm kind of thinking along the lines of "How do we sense acceleration at all?"
I think he answered your question. We sense acceleration by the force that goes along with it. So we can know our frame is not accelerating. We then measure each other frame, with respect to ours, and see which one has non-zero acceleration.
No idea what you mean by "sense". Physics is about measuring things. Proper acceleration is measured by accelerometers. Coordinate acceleration is measured with rulers and clocks.
I mean, if you are standing still in the center of the accelerating frame, the inertial frame appears to accelerating (like standing on the train, looking at the person on the station platform). But from the point of view of the inertial frame, the accelerating frame appears to be, well, accelerating (like the person on the platform watching the train).
But given that both frames can appear to be accelerating because of the reasoning above, what would determine which one is actually accelerating? My point of the example above is that you could say that the train station (or more generally, the earth) is accelerating relative to the train.
You can check whether your frame in accelerating without looking at another frame. That is, you can measure your acceleration without appealing to any other external frame.
The same cannot be said about velocity. You cannot measure your velocity without looking at another frame.
Velocity - frame dependent, depends on what frame you are comparing too.
Acceleration - not frame dependent. You can measure it within your frame without looking at another one. (measure it personally by sensing the force or measure it scientifically with an accelerometer)
I'm sensing that I have to go and understand how an accelerometer works more deeply... :P Thanks for the help, I will check out the accelerometer before I ask any more questions!
FAQ: Questions about accelerated frames of reference
1. What is an accelerated frame of reference?
An accelerated frame of reference is a coordinate system that is undergoing acceleration with respect to an inertial frame of reference. This means that the speed or direction of the frame of reference is changing, causing objects within that frame to experience non-zero acceleration.
2. How is an accelerated frame of reference different from an inertial frame of reference?
An inertial frame of reference is a coordinate system that is not undergoing any acceleration. This means that objects within the frame will either be at rest or moving at a constant velocity. In contrast, an accelerated frame of reference will have objects that experience non-zero acceleration.
3. Why is the concept of an accelerated frame of reference important in physics?
Accelerated frames of reference are important in physics because they allow us to understand how objects behave in non-inertial situations. Many real-world scenarios involve acceleration, such as a car turning a corner or a roller coaster going down a hill. By understanding how objects behave in these situations, we can make accurate predictions and design systems that are safe and efficient.
4. How do you calculate the acceleration of an object in an accelerated frame of reference?
In order to calculate the acceleration of an object in an accelerated frame of reference, we must take into account both the acceleration of the frame itself and the acceleration of the object within that frame. This can be done using equations such as Newton's second law (F = ma) and the equation for centripetal acceleration (a = v^2/r), depending on the specific scenario.
5. Can an object in an accelerated frame of reference ever have a constant velocity?
No, an object in an accelerated frame of reference cannot have a constant velocity. This is because the frame itself is experiencing acceleration, which means that the velocity of the object within that frame will also be changing. In order for an object to have a constant velocity, it must be in an inertial frame of reference.
