Questions about batteries and magnets and EM induction
In summary, the questions asked by the user could be answered by reading the following:-Batteries can be used to power low-voltage dc circuits-Series connection of two or more batteries amplifies the battery voltage-The voltage from one battery is 1.5V-Using a low voltage battery to power an electromagnet can result in a weak magnetic field
albertrichardf
165
Hello,
I wanted to ask a few questions regarding magnets and batteries, and EM induction.
First off, could I use batteries to replace a low voltage dc power supply, like say 2 V or so by connecting the ends of the battery in series to a circuit? As an extension, could I connect two batteries in series to obtain double the voltage? Is it ok to use two batteries in series with different voltage ratings, like say, an AAA and an AA?
If I could, what would be the voltage I could obtain from one battery? As in, say I use one AA battery, which is rated as 1.5 V. Do I obtain a full 1.5 V with one battery, or is it 0.75 V?
Another question is whether I could power an electromagnet with a voltage way lower than what is indicated. I have a 230 -255 rated ac-V magnet, which I got by halving and removing the upper half of a microwave transformer. I replaced the primary coil in it. It looks like this:
Could I power it with a voltage in the range of 2-10 V dc? What would be the effect on its magnetic field? Would it be strong enough to induce a current in the mA range?
Also, with such an electromagnet, what is the relationship between the current and the magnetic field strength?
Finally, suppose I use an electromagnet to induce a current in a loop of wire. How could I connect a voltmeter to measure the induced emf? In series with the circuit, or in parallel to the circuit?
Thanks for answering the questions. I know there are a lot.
Wow, lot's of questions. Let me try to answer some of them.
Albertrichardf said:
Hello,
Yes, you can put two or more batteries in series to increase the voltage. Two AA batteries in series will give you 3V, three in series will give you 4.5V, etc. Note that AA and AAA batteries are both 1.5V. It's not a good idea to put different batteries like AA and AAA in series because they will discharge at different rates.
You get the full 1.5V from a AA battery.
You could do this, but with a much lower voltage you will get a much lower current and hence a much lower magnetic field. Try using a multimeter to measure the resistance of the coil. Then you can calculate how much current will flow from Ohm's law.
Could I power it with a voltage in the range of 2-10 V dc? What would be the effect on its magnetic field? Would it be strong enough to induce a current in the mA range?[
Note that induction requires a changing magnetic field. A constant current and a constant magnetic field will not induce any current.
The magnetic field is proportional to the current times the number of turns, but to calculate the proportionality constant you need to know the details of the electromagnet.
You normally measure voltage by putting the meter in parallel with the circuit, and measure current by putting the meter in series with the circuit.
Likes albertrichardf
Thanks for answering all the questions.
I plan on changing the area of the circuit in which I am inducing a current, while keeping the magnetic field constant. And I also plan on keeping the area constant and changing the magnetic field by using a rheostat to change the resistance of the circuit powering the magnet, and thus the current through it. In fact that is why I wanted to know whether the magnetic field was proportional to the current, so that I would know how it changed with the resistance of the circuit. I now know that the changes are themselves proportional to each other, and that was all I needed. I'm actually trying to compare the effects of changing the area of a circuit compared to changing the magnetic field strength.
I'll also try measuring the magnet's resistance using the multimeter.
About measuring the voltage, I'm still not sure I understand. I know that normally you connect the voltmeter in parallel across a component to measure the voltage difference, and that you could connect the meter in parallel to the power supply to measure the voltage of the whole circuit, but in this case, my circuit is just a closed loop of wire, powered through an induced voltage. Would I still be able to measure the voltage if I connected the voltmeter in parallel to that, even if it was connected parallel to any part of the circuit anywhere?
Thanks.
I see your question. You're right, in this case you want to break the loop and put the voltmeter across the broken loop to measure the induced voltage, like in the attached picture.
  • VM.pdf
Alright. Thank you for answering
Related to Questions about batteries and magnets and EM induction
1. How do batteries work?
Batteries work by converting chemical energy into electrical energy. Inside a battery, there are two electrodes (an anode and a cathode) separated by an electrolyte solution. When the battery is connected to a circuit, a chemical reaction occurs at the electrodes, causing a flow of electrons from the anode to the cathode, generating an electrical current.
2. What is the difference between a battery and a magnet?
A battery is a device that stores and converts chemical energy into electrical energy, while a magnet is a material that produces a magnetic field. The function of a battery is to provide a source of electricity, while the function of a magnet is to attract or repel other magnets or magnetic materials.
3. How do magnets work?
Magnets work by creating a magnetic field, which is a force that can attract or repel other magnets or magnetic materials. This field is created by the alignment of electrons in the atoms of the magnet, causing a north and south pole. When two magnets with opposite poles are brought together, they attract; when two magnets with the same pole are brought together, they repel.
4. What is electromagnetic induction?
Electromagnetic induction is the process of creating an electrical current in a conductor by changing the magnetic field around it. This can be achieved by moving a magnet near a conductor or by changing the magnetic field strength near a conductor. This process is the basis for many electrical devices, such as generators and transformers.
5. How do batteries and magnets relate to electromagnetic induction?
Batteries and magnets are both involved in electromagnetic induction. Batteries produce an electrical current through chemical reactions, while magnets create a magnetic field. When a conductor, such as a wire, is placed in the magnetic field created by a magnet, it can induce an electrical current to flow through the wire. This is the basis for many electrical devices, such as motors and generators.
  • Electrical Engineering
