Questions about bayronic acoustic oscillations
In summary: This is not an accurate statement. The present day is the present time, which is now. The inflationary epoch refers to the time before the present day.
Buzz Bloom
467
TL;DR Summary
I have been trying to understand the abstract and introduction to the paper
https://arxiv.org/pdf/astro-ph/0501171.pdf
DETECTION OF THE BARYON ACOUSTIC PEAK IN THE LARGE-SCALE CORRELATION FUNCTION OF SDSS LUMINOUS RED GALAXIES.
I made an effort to find in the paper the answers to several questions, but I did not succeed. It may be that the answers could be in papers cited at the end of the article, but I do not have access to the journals cited.
Summary: I have been trying to understand the abstract and introduction to the paper
I would much appreciate any help readers of this thread might be able to provide. Here is a quote (citations omitted) from the introduction that raised the questions in my mind.
Because the universe has a significant fraction of baryons, cosmological theory predicts that the acoustic oscillationsin the plasma will also be imprinted onto the late-time power spectrum of the non-relativistic matter. A simple way to understand this is to consider that from an initial point perturbation common to the dark matter and the baryons, the dark matter perturbation grows in place while the baryonic perturbation is carried outward in an expanding spherical wave. At recombination, this shell is roughly 150 Mpc in radius.​
Because the central perturbation in the dark matter is dominant compared to the baryonic shell, the acoustic feature is manifested as a small single spike in the correlation function at 150 Mpc separation.​
Below are the questions.
1. What is the standard deviation for this 150 Mpc estimate of the end radius of a propagation spherical shell?​
2. What caused the start of each spherical shell of acoustic propagation? (With my limited imagination, I am guessing it was something like an explosion of some sort. How would this relate to a perturbation in density?)​
3. At what universe age did these acoustic waves begin?​
4. Am I correct that the propagation of these waves ended at the time of recombination (which is the beginning of the CMB)?​
5. What were the speeds of propagation at the start and end of propagation?​
6. Did the speed of propagation change with changes in temperature and density as related to the scale factor?​
Space news on Phys.org
Not sure if this will answer all your questions but PBS Spacetime do a decent video about them here:
Likes Motore
I don't know the precise answer to this, but the error bars are pretty small for sure. I don't think you should take 150Mpc as an accurate value itself, because they are only attempting to give a broad picture of the processes involved in that context, not provide accurate measurement values.
Not any sort of explosion, no. The spherical model is just a heuristic way to understand what's going on, and I don't think it's used in real calculations. The physical picture here is one where there is a spherical overdensity (basically, a collection of dark matter). The baryons fall into the overdensity, then bounce back out.
The acoustic waves themselves would have started immediately after reheating. However, only waves which are smaller than the horizon scale can oscillate. In the very early universe, the horizon scale was quite short, so most of the pressure differences were "stuck" in place. As the expansion slowed, the horizon scale increased, and the pressure differences started to become traveling waves.
Those initial pressure differences were once quantum vacuum fluctuations during inflation, fluctuations which were expanded to cosmic scales by the rapid accelerated expansion during inflation.
Yes, essentially.
Roughly half the speed of light:
http://www.astro.ucla.edu/~wright/BAO-cosmology.html
I think only loosely, as photons make up a large fraction of the fluid density/pressure.
Likes Buzz Bloom
Hi kimbyd:
Thank you very much for your answers and the reference citation.
I am unfamiliar with the "reheating" concept. Would you please elaborate a bit.
ADDED
Never mind. I found
https://en.wikipedia.org/wiki/Inflation_(cosmology)#Reheating
Regards,
Buzz
Likes kimbyd
Hi Mikee:
My overall impression of the video is that it is poor. I think several of the things said are the kind of descriptions that generally will confuse and mislead most of the people who will see it. Here is a quote of one such faux pas.
. . . from when the universe was subatomic in size.​
It may be simply a careless misspoken phrase, and he meant to say "observable universe".
In spite of my overall impression, I did learn a few things related to my questions. However, the few somewhat useful answers I feel were much more clearly explained in @kimbyd's post #4.
Regards,
Buzz
Hi @kimbyd:
Congratulations for your award for the Astro/Cosmo award. I think it was well earned.
I am hoping you can explain about the use of the 150 Mpc (500 Mly) phenomenon in calculating universe curvature. The video in @MikeeMiracle's post #2 described the use as an expected average value related to the closest distance between pairs of galaxies. I can make a guess about how that relates to curvature, but to me this seems to be based on a careful choosing of the galaxy pairs. For example, Andromeda is only 2.5 Mly away from the Milky-way, so Milky-way-Andromeda would not be a good choice.
This reminds me of a life experience story my wife tells about her freshman physics lab at MIT measuring the speed of light. She does not remember details, but she remembers a repetition of getting the wrong answer, and making adjustments before trying again. This process was continued until she got an answer close to the actual value she knew was correct. Then she stopped experimenting. From this experience she decided to switch her major from physics to math.
Regards,
Buzz
Hi Buzz
Yeah I think the videos are made so that they can be followed by those without all the technical background knowledge so it's easier to simplify some explanations...like for myself. :)
I do believe is answered your questions 2, 3 & 5 though which is why I posted it as I thought you might find it useful. Also a brief simplified overview for us less knowledgeable users of PF.
Hi @MikeeMiracle:
I do appreciate your post, and your effort to help me understand the BAO phenomenon. I am now becoming aware of just how complicated and difficult to understand this topic is. I am now focussing on wanting to understand the diagram discussed at 4 miniutes into the video. I found the source of the diagram as Figure 2 on page 5 of
I have tried to find in the article an explanation which I can understand of what Figure 2 is communicating (not just conclusions from it), but I failed. I plan to soon start a new thread with several specific questions about this diagram.
Regards,
Buzz
Regarding the first peak in the CMB angular power spectrum you will find some more background here:
https://lambda.gsfc.nasa.gov/product/map/dr1/pub_papers/firstyear/peaks/wmap_powspec_peaks.pdfPage 4
"In a flat geometry with known b and m, the quantity that is particularly well determined is the acoustic horizon size, rs . From equation 2 we find rs = 143+- 4 Mpc."
Likes Buzz Bloom
Buzz Bloom said:
Summary:: I have been trying to understand the abstract and introduction to the paper
Baryonic Acoustic Oscillations (BAOs) began as the radiation dominated era gave way to matter domination at ~60,000 years after inflation and continued through about 380,000 years when photon wavelengths stretched (and their energies dropped) to below that needed to ionize hydrogen (3000K). After ~380,000 years, atomic hydrogen formed and allowed photons to stream out - giving us a snapshot of the Universe at that time, the "Last Scattering Surface." If you are unfamiliar with BAOs: they were areas of matter overdensity (primarily dark matter) that then pulled in additional matter - resulting in baryonic matter and photons flowing inward, then rebounding out as sound waves in the then existing hot plasma, moving at about half the speed of light and traveling outward as spherical density wave rings. The largest waves, representing the fundamental wavelength of a group of harmonically related wavelengths, ended their outward motions (for the most part) when the Universe cooled to below ~3000K, at which point photon energies dropped to below that required to ionize hydrogen and disconnecting photon from their earlier interactions and therefore no longer drove the baryonic matter waves. The radius of those waves from their respective BAO centers yield spherical rings with distances that are directly related to their travel time (60,000 through 380,000 years) and the speed of sound in the medium (as above). That radius then is of a known size, which when multiplied by the appropriate spatial expansion factor, yields a "measuring stick" by which we can measure spatial geometry today.
Likes Buzz Bloom
Related to Questions about bayronic acoustic oscillations
1. What are baryonic acoustic oscillations?
Baryonic acoustic oscillations (BAOs) are periodic fluctuations in the distribution of matter in the universe. They are a result of sound waves that traveled through the early universe, leaving a distinct pattern in the distribution of galaxies and dark matter.
2. How are baryonic acoustic oscillations detected?
BAOs are detected through large-scale surveys of galaxies and their distribution in the universe. By measuring the clustering of galaxies at different distances, scientists can identify the characteristic pattern of BAOs.
3. What can baryonic acoustic oscillations tell us about the universe?
BAOs provide important information about the expansion rate of the universe and the amount of matter and dark energy present. They also help in understanding the growth of large-scale structures in the universe.
4. How do baryonic acoustic oscillations relate to dark energy?
BAOs are affected by the presence of dark energy, which is a mysterious force that is causing the expansion of the universe to accelerate. By studying the effects of dark energy on BAOs, scientists can better understand its properties and behavior.
5. What is the significance of studying baryonic acoustic oscillations?
Studying BAOs is important for understanding the fundamental properties of the universe, such as its expansion rate, composition, and evolution. It also helps in testing and refining theories of cosmology and the origin of the universe.
  • Cosmology
  • Classical Physics
  • Cosmology
