Questions about finding values of a tangent
  • Thread starter J-Girl
  • Tags
    Tangent
In summary, To find the value(s) of k, you need to solve the equation x^2 + (-x+k)^2 - 2x + 4(-x+k) = 72, which is a quadratic equation in x. The resulting equation will have either 0, 1, or 2 solutions, and you can determine the necessary value of k to make it have only one solution. This will give you the value(s) of k for which the line x+y-k=0 is a tangent to the circle x^2+y^2-2x+4y-72=0.
J-Girl
38
Hi there:) so i have gotten this question in my homework, and its not that i don't understand how to find a tangent to a curve, i just don't understand this question!:(:( so here it is:
"The line x+y-k=0 is a tangent to the circle x^2+y^2-2x+4y-72=0. Find the value(s) of k.
Does this mean i am to solve the equation as a quadratic, and obtain the values of x to find the values of k?
I have tried to solve it as y=sqrt(-x^2+2x-4y+72),but the graph turned out totally different from the first one.
could anybody hely me? would really appreciate it!:)
You don't need to do any calculus to solve this problem.
Do a little algebra to show that the circle is centered at (1,-2) and has a radius of sqrt(77).
You know that the slope of the line is dy/dx = -1, and you should know intuitively what points on the circle should have that slope.
Then all you need to do is calculate where those points are and you can solve for the necessary k to have the line pass through the points.
Although brunnels says, you don't really need to use Calculus. (Although I see that he then refers to the derivative!) A line either misses a circle completely, or crosses it in two points, or is tangent to it. Of course, if the line is either tangent to the circle or crosses it in two points, the (x, y) coordinates at a point of intersection must satisfy both equations:
y= -x+ k and [itex]x^2+ y^2- 2x+ 4y= 72[/itex]
Replace each y in the equation of the circle by -x+ k and you have a quadratic equation for equation in x. Now, under what conditions does that equation have 0, 1, or 2 solutions? What must k equal so that the equation has only one solution?
FAQ: Questions about finding values of a tangent
What is a tangent?
A tangent is a line that touches a curve at exactly one point, without intersecting it. In mathematics, it is defined as the ratio of the length of the side opposite an angle in a right triangle to the length of the adjacent side.
How do I find the value of a tangent?
The value of a tangent can be found using trigonometric ratios, specifically the tangent function. To find the value of a tangent, divide the length of the side opposite the angle by the length of the adjacent side.
What is the unit of measurement for the value of a tangent?
The value of a tangent is a ratio, so it is a dimensionless quantity and does not have a unit of measurement.
Can the value of a tangent be negative?
Yes, the value of a tangent can be positive, negative, or zero, depending on the angle and the sides of the triangle. A positive value indicates that the angle is acute, while a negative value indicates that the angle is obtuse.
How is the value of a tangent used in real-life applications?
The tangent function is used in various fields, such as engineering, physics, and astronomy. It can be used to calculate the height of objects, the slope of a hill, or the trajectory of a projectile. It is also used in navigation and GPS systems to determine the angle of elevation or depression of an object.
