Questions about geometric albedo and phase angle
In summary, during a full moon, the moon is not perfectly or completely illuminated due to slight deviation. Full phase is defined as maximum illumination in relation to the lunar cycle, not complete illumination. Eclipses occur when the Earth blocks sunlight from the moon, which is when a truly complete full moon would have occurred.
nnj
If our sun is the source of illumination, how can an object be observed from the Earth at full phase? Wouldn't the Earth eclipse the object? So then why can we see a full moon during full phase? Is it because the moon's orbit is inclined wrt to the Earth-Sun orbit? If so then wouldn't this by definition not be full phase?
Astronomy news on Phys.org
You're right, full phase isn't perfectly-completely illuminated... but the deviation is small. Full phase is defined relative to the lunar cycle, i.e. full = maximum, not complete illumination. Eclipses do happen when the Earth blocks the sunlight from the moon---which is when it would have been a truly complete full-moon.
Related to Questions about geometric albedo and phase angle
1. What is geometric albedo?
Geometric albedo is a measure of the reflective properties of a non-transparent surface, such as a planet or moon. It is the ratio of the amount of light reflected by an object at zero phase angle (directly facing the light source) to the amount of light that would be reflected by a perfectly diffusing disk with the same size and distance from the light source.
2. How is geometric albedo different from Bond albedo?
Bond albedo is a measure of the total amount of light reflected by an object, taking into account both direct and diffuse reflection. Geometric albedo only considers direct reflection at zero phase angle, while Bond albedo considers all angles of incidence. Therefore, geometric albedo is typically lower than Bond albedo for a given object.
3. What factors affect the geometric albedo of an object?
The geometric albedo of an object is affected by its composition, surface texture, and the wavelength of light being reflected. Objects with smooth, highly reflective surfaces tend to have higher geometric albedos, while objects with rough or dark surfaces have lower albedos. Additionally, objects with a higher proportion of light-colored materials, such as ice or snow, will have a higher geometric albedo.
4. How is phase angle related to geometric albedo?
Phase angle is the angle between the observer, the object, and the light source. As the phase angle increases, the amount of direct light reflected by an object decreases, leading to a decrease in geometric albedo. This is because at higher phase angles, more of the object's surface is in shadow, leading to a lower overall amount of light being reflected towards the observer.
5. Why is geometric albedo important in planetary science?
Geometric albedo is an important property to measure in planetary science because it can provide information about the composition and surface properties of objects in our solar system. By comparing the geometric albedos of different objects, scientists can gain insights into their surface materials and processes, as well as their overall evolution. Additionally, geometric albedo can be used to calculate the energy balance of planets and moons, which is crucial for understanding their climates and potential habitability.
  • Astronomy and Astrophysics
