Questions About Gravitational Waves
In summary: Corollary to #2: Ought we to expect gravitational waves to undergo Doppler effects?Yes, gravitational waves will undergo Doppler effects.
Ontophobe
60
1. If the Michelson-Morley experiment were to be conducted with gravitational waves instead of light waves, would the results be any different?
2. Ought we to expect the existence of "gamma" gravitational waves and "radio" and "microwave," etc. gravitational waves? In principle, could there be a "gravitational microwave background?"
3. Corollary to #2: Ought we to expect gravitational waves to undergo Doppler effects?
4. Back when we thought light moves through an ether, we hypothesized (based on the nature of light) that the ether must be something akin to a really rigid glass. We no longer believe in the ether, but we do believe in a "spatio-temporal fabric" (tomayto/tomahto) through which gravitational waves move. Given the nature of gravitational waves, to what material substance would we compare the fabric of space-time? Glass? Rubber? Water?
Yes, you will have a very hard time finding a gravitational beam splitter and a gravitational wave mirror. You simply cannot do the MM experiment with gravitational waves as they will go right through your experimental setup.
Yes, gravitational waves can have different frequencies. Different frequencies of gravitational waves are predicted by different phenomena. Gravitational waves from the very early Universe would essentially probe the physics of inflation and not be due to a thermal background.
No we don't. This is just a popularised figure of speech to describe what is really going on in the theory. The rest of this question therefore makes no sense.
So gravity waves aren't waves in space-time, in contrast to EM waves which are waves in a field of potentials in space-time? Space-time isn't actually a thing (albeit non-material)? With what should I replace this popularized fiction?
Related to Questions About Gravitational Waves
1. What are gravitational waves?
Gravitational waves are ripples in the fabric of space-time that are created by massive objects moving through space. They were predicted by Albert Einstein's theory of general relativity and were first observed in 2015.
2. How are gravitational waves detected?
Gravitational waves are detected using highly sensitive detectors called interferometers. These instruments use lasers to measure tiny changes in the distance between two points caused by passing gravitational waves.
3. What is the significance of detecting gravitational waves?
Detecting gravitational waves provides evidence for the existence of black holes and other massive objects predicted by Einstein's theory of general relativity. It also allows us to study the properties of these objects and the effects of extreme gravitational forces.
4. Can gravitational waves be used for communication or travel?
No, gravitational waves cannot be used for communication or travel. They are extremely weak and would require a massive amount of energy to produce a detectable signal. Additionally, they can only travel at the speed of light, making them too slow for practical use.
5. How do gravitational waves differ from electromagnetic waves?
Gravitational waves are fundamentally different from electromagnetic waves. Electromagnetic waves are caused by the oscillation of electric and magnetic fields, while gravitational waves are caused by the distortion of space-time. Additionally, gravitational waves can pass through any material without being affected, whereas electromagnetic waves can be absorbed or reflected by certain materials.
