Questions about Laplace's equation and Green's functions
In summary, we have discussed the Laplacian operator in two dimensions and its form in polar coordinates. We have also addressed the use of the method of images in solving the equation grad^2 = Dirac delta function and how it can be applied to question 3(iv) in the exam paper.
gangsta316
30
http://workspace.imperial.ac.uk/mathematics/public/students/ug/exampapers/2010/M2AA2-2010.PDF
Questions 3(iii) and 3(iv)
3(iii)
So here we "guess" that the solution is f = f(r) (f for phi). Then we just have to solve an ODE. But the mark scheme says that we get
1/r^2 * d/dr (r^2 *df/dr) = 1
Why?
The Laplacian is
http://en.wikipedia.org/wiki/Laplace_operator#Two_dimensions
that.
So wouldn't we get
1/r *d/dr (r* df/dr) = 1?
3(iv)
How is this question done? I know that, with the method of images, we want to solve grad^2 = Dirac delta function, and we extend it to the whole of R^3. Then we solve it and appeal to uniqueness to show that it's the solution for y>0. But what would we do here?
Thanks for any help.
Thank you for your post. I am a scientist and I would like to address your questions regarding questions 3(iii) and 3(iv) from the exam paper you have linked.
For 3(iii), the reason why the mark scheme gives 1/r^2 * d/dr (r^2 *df/dr) = 1 is because of the form of the Laplacian operator in two dimensions. As you have correctly pointed out, the Laplacian in two dimensions is given by the expression you have provided in your post. However, in this particular case, we are working with polar coordinates and not Cartesian coordinates. In polar coordinates, the Laplacian operator takes the form of 1/r *d/dr (r* df/dr) as you have mentioned. Therefore, when we substitute this into the equation 1/r^2 * d/dr (r^2 *df/dr) = 1, we get the correct form of the Laplacian in polar coordinates.
For 3(iv), the method of images can indeed be used to solve the equation grad^2 = Dirac delta function in three dimensions. However, in this case, we are only interested in solving the equation in the region y>0. Therefore, we can use the method of images to find the solution for y>0 and then use the uniqueness theorem to show that this is the only solution in this region. This is a common technique used in solving partial differential equations, where we extend the problem to a larger region and then restrict it to the region of interest.
I hope this helps to clarify your doubts. If you have any further questions or need further explanation, please do not hesitate to ask. Good luck with your studies!
FAQ: Questions about Laplace's equation and Green's functions
What is Laplace's equation and why is it important?
Laplace's equation is a second-order partial differential equation that describes the distribution of a scalar field in a given region. It is important because it has many applications in physics, engineering, and mathematics, such as in electrostatics, fluid mechanics, and potential theory.
What are Green's functions and how are they related to Laplace's equation?
Green's functions are a type of mathematical function that can be used to solve certain types of boundary value problems, including those involving Laplace's equation. They are related to Laplace's equation through a process called convolution, which allows for the solution of the equation to be expressed in terms of Green's function.
How are Laplace's equation and Green's functions used in practice?
In practice, Laplace's equation and Green's functions are used to solve various physical and engineering problems, such as finding the electric potential in a region with given boundary conditions or determining the displacement of a structure under external forces. They are also used in numerical methods and simulations to model and analyze complex systems.
Can Laplace's equation and Green's functions be applied to non-linear systems?
No, Laplace's equation and Green's functions are only applicable to linear systems. Non-linear systems require more complex mathematical tools for their analysis and solution.
What are some common techniques for solving Laplace's equation using Green's functions?
Some common techniques for solving Laplace's equation using Green's functions include separation of variables, method of images, and the method of characteristics. These techniques involve manipulating the equation to reduce it to a simpler form that can be solved using Green's functions and other mathematical methods.
