Questions about Legendre Equation
  • Thread starter AlonsoMcLaren
  • Tags
    Legendre
In summary, the Legendre Equation has a solution at x=±1, which is related to θ in spherical coordinates. To ensure a polynomial solution, l must be an integer and the coefficient c2 of the function Ql(x) must be zero. However, this assumption only applies if the solution at x=±1 must be found through a power series. To solve the Legendre Equation for |x|>1, one can use the eigenfunctions of the Legendre operator, known as the Legendre polynomials.
AlonsoMcLaren
90
1. I understand that the x in Legendre Equation (1-x^2)y''-2xy'+l(l+1)y=0 is often related to θ in spherical coordinates. We want the latter equation to have a solution at θ=0 and θ=pi. Therefore, we require that Legendre Equation has a solution at x=±1
And it is claimed that "we require the equation to have a polynomial solution, and so l must be an integer. Furthermore, we also require the coefficient c2 of the function Ql(x) (Legendre's function of the second kind) to be zero" But this assumes that at x=±1 the solution of Legendre Equation MUST be found by a power series. Having a solution at x=±1 is not the same as having a power series solution at x=±1.
2. How to solve Legendre Equation with |x|>1?
The "Legendre polynomials" are eigenfunctions for the Legendre operator. That means that any solution can be written as a (possibly infinite) sum of Legendre polynomials.
Related to Questions about Legendre Equation
1. What is the Legendre equation and why is it important in science?
The Legendre equation is a second-order linear differential equation that is used to describe physical phenomena in various fields of science, such as physics, engineering, and mathematics. It is important because it helps us model and understand natural phenomena, such as the motion of particles and the behavior of waves.
2. Who was Adrien-Marie Legendre and what was his contribution to the development of the Legendre equation?
Adrien-Marie Legendre was a French mathematician who lived in the 18th and 19th centuries. He is best known for his work in number theory, but he also made significant contributions to the development of the Legendre equation and its applications in physics and engineering.
3. What are some real-world applications of the Legendre equation?
The Legendre equation has many real-world applications, including in the study of heat transfer, electromagnetic fields, fluid mechanics, and quantum mechanics. It is also used in signal processing, image processing, and statistical analysis.
4. How is the Legendre equation solved?
The Legendre equation can be solved using a variety of methods, such as power series, Frobenius series, and recurrence relations. The specific method used depends on the form of the equation and the boundary conditions of the problem.
5. What are some extensions of the Legendre equation?
There are several extensions of the Legendre equation, including the associated Legendre equation, which is used to solve problems with spherical symmetry, and the modified Legendre equation, which is used to solve problems with cylindrical symmetry. There are also higher-order Legendre equations, which are used to model more complex physical phenomena.
  • Differential Equations
  • Classical Physics
