Questions about light(wave and dual nature)
In summary: The fields, right? So the wavelength of light is simply the distance the oscillating fields travel?In summary,Ok, so according to the information provided, light consists of oscillating fields. When a particle like an electron moves, what is oscillating? The fields, right? So the wavelength of light is simply the distance the oscillating fields travel?
eightsquare
96
Ok, so I have many questions about light. My basic understanding can be seen here:
http://answers.yahoo.com/question/index?qid=20140117062517AAeH0Dh
My first question is, consider transverse waves in water. As the wave moves out, the water molecules move up and down forming the crests and troughs. Considering light, as light moves out, if my understanding in the link above is correct, then the FIELDS are oscillating, i.e. changing in magnitude(in place of the water molecules), and along the line that the light moves(not actually up and down in space,like the water molecules). The frequency is the number of times the strength of the field goes from maximum to minimum and back to maximum in a second, and the wavelength is the distance the light travels when one such cycle is completed.
If what I have said above is right, how can this be translated to wavelengths of material particles(say like a photon). It is not possible for the material particle to oscillate at a point, right?
Science news on Phys.org
Your understanding is mostly correct. The oscillation is the electric and magnetic field vectors. That is, the field "points" in a particular direction that oscillates back and forth. So when the EM wave interacts with an antenna it will cause the charges to move in one direction and then the other.
How does this relate to a photon? The short answer is that the EM wave interacts with matter only in discrete packets of energy that we call photons. This means that the photon isn't a particle in the sense of being a hard little ball and it is not a wave in itself. It is a manifestation of how the EM wave interacts with everything else.
Thanks. So, in the same way, particles like electrons are particles only when they interact with something else(other particles, say a proton in this case) and otherwise they can be considered to be waves? So the wavelength here does not mean the particle rides along a 'loop' but rather it refers to the wave nature of the particle, which only manifests itself as a particle during interactions? And, lastly, in the case of light, the fields are oscillating. When a particle like an electron moves, what is oscillating?
FAQ: Questions about light(wave and dual nature)
1. What is the difference between light as a wave and light as a particle?
Light can behave as both a wave and a particle, depending on the experimental setup. As a wave, light exhibits properties such as interference and diffraction, while as a particle, it can transfer discrete packets of energy known as photons.
2. How does light travel through space?
Light travels through space as an electromagnetic wave, which means it does not need a medium to propagate. This is because light is composed of oscillating electric and magnetic fields that can self-propagate.
3. What is the dual nature of light?
The dual nature of light refers to its ability to behave as both a wave and a particle. This phenomenon, known as wave-particle duality, was first proposed by Albert Einstein and has been confirmed through various experiments.
4. How is the wavelength of light related to its energy?
The wavelength of light is inversely proportional to its energy. This means that as the wavelength increases, the energy of the light decreases. This relationship is described by the equation E = hc/λ, where E is the energy, h is Planck's constant, c is the speed of light, and λ is the wavelength.
5. Can light travel through different mediums?
Yes, light can travel through various mediums, such as air, water, and glass. However, the speed of light may change depending on the density and composition of the medium. This can result in phenomena such as refraction and dispersion.
9K
