- #36
agentredlum
- 484
micromass said:Proof for that, please?
Answer the question
agentredlum said:Answer the question
micromass said:You didn't ask any question.
You made an assertion, which I ask you to prove.
agentredlum said:Here it is AGAIN
What is the probability that you have something that factors nicely?
agentredlum said:Assuming uniform probability distribution for the co-efficients.
If it is more than 0 + delta(e) where delta(e) goes to zero, I would be surprised.
Attempting to factor is a waste of time.
micromass said:That probability is 1. I can factor each quadratic equation.
Your turn: prove your previous assertion.
agentredlum said:Uh-hmmmmm
I think you have some problems understanding the English language.
It is a waste of time answering your challenges, you will disagree anyway.
Robert1986 said:This:
"If it is more than 0 + delta(e) where delta(e) goes to zero"
doesn't even make sense. What do you mean by "goes to zero".
Aside from that, let's just say that the coefficients of a general quadratic equation have a uniform distribution across the reals (in text-book problems, I'd bet $1 Million that this is not the case) and that I just won't try to factor the quadratic into linear factors without using the QF. You are still missing the point that it is much easier for me (and I'd imagine for people who have been using the QF for more than 3 weeks) to look at the equation and determine without writting anything down what I need to put into my QF than it is to say "gee, ok, let me see, this is the first form which means I need to use this QF."
Again, your QF is simply a minor algebraic tweak (AS I PROVED) of the normal QF. You have done nothing.
agentredlum said:I posted the 'trick'
You keep claiming it's your proof
That's not honest.
Robert1986 said:May I ask a question? What math classes have you taken, agentredlum? Have you taken the Calc. sequence, yet?
That's not honest.
micromass said:No, he's claiming that your trick is absolutely trivial and useless.
agentredlum said:I have completed calc 1, 2, 3 all A using Stewarts book
completed Linalg with A
Every math course i have taken, i did not get less than A
I worked 10 years as co-ordinator of math learning center at university.
Not only have i helped students but all tutors would come to me when they got stuck.
I have used the QF thousands of times, pen to paper so your comments about 3 weeks and 4th grade math are hurtfull
Robert1986 said:I never ever said I came up with the "trick"; I gave a very simple proof that your trick worked. There is nothing at all dishonest about that. The proof is, in fact, mine.
Who gets credit for the proof of FLT? Fermat or Wiles?
I rest my case.
Robert1986 said:Well, it has been my experience (again, this is just my experience) that after using the QF for about 3 weeks, it is no longer necessary for most students to explicitly write out what they are doing.
That wasn't my question. My question was who gets credit for the proof. It was Fermat's idea but Wiles gave a proof. The "trick" is your idea, but I gave a proof. Therefore, I get credit (but not much credit because it is, after all, a trivial thing to prove) for the proof I gave. It is pretty simple.agentredlum said:To be honest you can't mention Wiles without mentioning Fermat
agentredlum said:You used the 'trick' i posted without mentioning where you got it.
agentredlum said:If the people writing the texts knew it could be done that way... they would show it.
agentredlum said:Well, if you work at a learning center where every day you have to show students STEP BY STEP how to use a formula... you might start thinking about some shortcuts.
My own personal opinion of the matter is...If the people writing the texts knew it could be done that way... they would show it.
agentredlum said:It is folly to do with more when you could do with less- Occam's Razor
micromass said:What I cannot understand is this: how can somebody who completed calc I,II,III and linear algebra think that your trick is nontrivial and useful?? I really cannot grasp that.
Everybody I know would call your trick a trivial result and wouldn't defend it as hard as you do.
It's like saying that the quadratic equation
[tex]ax^2+bx+c=0[/tex]
has a root given by
[tex]\frac{\sqrt{b^2-4ac}-b}{2a}[/tex]
and somehow claim that above formula does not follow trivially from the quadratic formula and that the formula is useful somehow...
agentredlum said:You are using the word trivial to mean useless.
Robert1986 said:This is why I prefer to remember one QF and not 4.
micromass said:No, I didn't.
agentredlum said:Many times, in many posts you and others said there was no use for it. Even only as a curiosity it is useful. It has computational advantages as well.
So what are you saying now?
It is trivial but useful?
agentredlum said:You keep saying this, even though I keep correcting you.
I don't use 4 formulas.
I only use 1 formula, the formula that minimizes operations.
You refuse to understand this-Occam's Razor
Robert1986 said:Ahh, I see. But it only minimizes operations when you have a quadratic in one particular form, correct?Anyway, I prefer the formula that is derived directly using the definition of a root of a function.
agentredlum said:5 out of 8 times you have problems i don't
agentredlum said:I NEVER have to compute a double negative for b
I NEVER have to compute a triple negative for +4ac
agentredlum said:Here is a fact about amicable numbers.
In 1636, Fermat found the pair (17296, 18416) and in 1638, Descartes found (9363584, 9437056), although these results were actually rediscoveries of numbers known to Arab mathematicians. By 1747, Euler had found 30 pairs, a number which he later extended to 60. In 1866, 16-year old B.*Nicolò I.*Paganini found the small amicable pair (1184, 1210) which had eluded his more illustrious predecessors (Paganini 1866-1867; Dickson 2005, p.*47).
http://mathworld.wolfram.com/AmicablePair.html
This 16 year old boy found something that escaped all the geniuses that came before him.
micromass said:The point is that we don't see minus signs as problems. A minus less or more means nothing to us...
agentredlum said:What does it mean to a computer, in terms of memory allocation?
