JR Richter
- 7
- TL;DR Summary
- If a reflected signal is redirected back to the transmitter and then back to the antenna feed point, why can't we measure this reflected power at the transmitter? Our forward power remains the same even with a SWR.
This could be a typical setup: We're transmitting a signal of 100W measured directly out of our Pa / Matching network into coaxial feed line. The feed line has a 52.2 -J0.31 Ohm impedance. The length of this coaxial feed line is 100'. The matched line loss of this feed line is .709dB/100' at 14.1 MHz. The feed line is connected to an antenna with a feed point Z of 200 + J0 Ohms.
We know from calculations that our SWR at the feed point is ~ 3.83. There will be an additional loss of .562dB due to impedance mismatch at the antenna. The total line loss will be .709dB + .562dB is 1.271 dB. Calculations show that we have ~ 74.6W at the antenna feed point. The remaining power of 25.3W is fed back to the transmitter. With line loss of .709dB the reflected power seen at the transmitter is 21.54W. This calculates out to ~ 2.98 SWR at the transmitter output.
Sorry for the calculations but just wanted to show where I am at with this example. Many authors have said that this power reflection is then sent back to the feed point of the antenna. I feel this reflected power is absorbed because of the perfect match at output of our transmitter.
My question is, If this power is truly sent back to the antenna, then why can't we see this reflected power on our forward power measurements? I can't imagine the final Pa throttling back or increasing its power to maintain the 100W output. Thanks Jr Richter
