Questions: about the force of gravity.
In summary, both the questions can be answered by considering G= g M m/ r^21d is for mindreaders, it depends on what kind of answer teacher wants to hear.Upon my knowledge the mass of an object is derived from intermolecular forces called higgs boson, where the P+ and N give and receive a 'force' (probably the wrong word but...) which gives the atom mass the gravitons present in the atom makes the mass of the object react to gravity.This probably didn't help much but is my input, which i find isreasonably good considering i am in yr 10 of schooling :rofl:Thanks for the help, but I am still confused.
Katt
I have two questions (stated below), but do not feel confident about my answers:
(1)Which of the following statements about the force of gravity is false?
a. it is a universal force, which acts everywhere in space
b. its strength decreases as the square of the distance
c. its strength is inversely proportional to the mass: the more mass, the less gravity
d. the force never becomes zero
e. it causes the paths of the planet to be ellipses and not straight lines.
(2) Newton's Law of Gravity, the force of gravity goes up as the:
a. mass goes down
b. mass goes up
c. distance does down
d. distance goes up
e. or more than one of the above
For the first problem I think c. is false because I thought the more mass you have the more gravity there is.
For problem (2), I think, "the force of gravity goes up" as the, (d.)distance goes down.
However, I am not sure. Hopefully, you can inform me on the correct answer.
(My apologies, if I am posting in the wrong section).
Both the questions can be answered by considering G= g M m/ r^2
This probably didn't help much but is my input, which i find isreasonably good considering i am in yr 10 of schooling :smile:
For the first problem, I was trying to see which problems were true statements, thus leaving 1 false one left.
This is where I am so far:
- I read that, " Gravity can never become zero. We can increase the separation and make the force as small as we like, but we can’t make it go away." So, d cannot be the false statement.
- "It is a Universal force that acts everywhere in space," is a true statement too. So, I think that (a) cannot be the false statement.
- "It causes the planets to be ellipses and not straight lines," is also true and not false.
So, if I am correct that leaves me with either (b) or (c) as the false statement, I do not not which one it is though.
Does it have to be one false answer? You posted confusing "statements is" phrase.
Take a look at the equation posted bu Shramana, it will tell you whether c is OK.
For the first problem: I have to find the statement that is false.
There is only 1 false statement out of the 5 choices listed.
So, I think c is the answer to problem(1) because it says "the more mass, the less gravity." That contradicts what I have read, which states, the more mass something has the greater the gravity. C must be the false statement and the other statements must be correct.
C it is then.
Ok!... So, that would mean for problem(2), that the force of gravity goes up as the, "mass goes up," all of which effects the distance...
The higher the mass, the stronger the gravity. That's true, but that's not all.
Let me try this again!
The force of gravity goes up as the "mass goes up" and,
the force of gravity goes up as the, "distance goes down" because gravity increases as the distance decreases.
Sounds good to me :approve:
Finally, I get it. Thanks everyone for the help.
Related to Questions: about the force of gravity.
1. How is the force of gravity calculated?
The force of gravity is calculated using Newton's Law of Universal Gravitation, which states that the force between two objects is directly proportional to the product of their masses and inversely proportional to the square of the distance between them.
2. What factors affect the force of gravity?
The force of gravity is affected by the mass of the objects and the distance between them. The larger the masses and the shorter the distance between them, the stronger the force of gravity.
3. Why do objects fall towards the Earth?
Objects fall towards the Earth because of the force of gravity. The Earth's mass creates a gravitational pull that attracts objects towards its center.
4. Does the force of gravity change at different locations on Earth?
Yes, the force of gravity can vary slightly at different locations on Earth due to variations in the Earth's shape and density. It is also affected by altitude, with gravity being slightly weaker at higher altitudes.
5. How does the force of gravity affect the motion of objects?
The force of gravity is responsible for the motion of objects in free fall, causing them to accelerate towards the Earth's surface at a rate of 9.8 meters per second squared. It also plays a role in the motion of objects in orbit around the Earth or other celestial bodies.
  • Mechanics
  • Beyond the Standard Models
  • Other Physics Topics
  • Classical Physics
  • Classical Physics
  • Classical Physics
