Questions concerning Dopplers Effect and Wave Phenomena
In summary, two men standing at different locations observe waves approaching at different frequencies. The speed of the waves is given and the question asks for a possible value for the speed of the boat and its direction. To solve this, the moving observer and moving source formulas can be used. In the second problem, a parallel beam of light with a certain wavelength passes through a slit and forms a diffraction pattern. The question asks for the angle of the first diffraction minimum for a different wavelength. The formulas to use for this problem can be found in resources on diffraction.
Daaniyaal
64
13. A man standing by the shore observes sea waves approaching at a frequency of 0.20Hz. A man on a boat observes that waves are approaching the boat at a frequency of 0.50Hz. The speed of the waves is 2.0ms–1. Which of the following gives a possible value for the speed of the boat and its direction?
A) 3.0 ms^-1 away from the shore
B) 3.0 ms^-1 towards the shore
C) 1.2 ms^-1 away from the shore
D) 1.2 ms^-1 towards the shore
f′= f[v/(v±u)]
f′= f[(v±u)/v]
I tried to use the moving observer formula and moving source formula but neither worked :(
Wave Phenomena:
A parallel beam of light with a wavelength 600 nm passes through a single narrow slit and forms a diffraction pattern on a screen. The angle at which the first diffraction minimum is formed is 2.0 × 10–3 rad.
What would be the angle of the first diffraction minimum for light of wavelength 400 nm?
A. 3.0 × 10–3 rad
B. 2.0 × 10–3 rad
C. 1.3 × 10–3 rad
D. 1.2 × 10–3 rad
I don't know which formulas pertain to these, I would love some resources on this subject too, thank you!
Hi Daaniyaal! Welcome to Physics Forums :smile:
f′= f[v/(v±u)]
f′= f[(v±u)/v]
How did you use the formula?
A hint : You can decide the direction by a little of intuition. The frequency as observed by the observer on the boat is more than the stationary observer. When does this happen?
For example, if a siren is buzzing past, when would you hear a higher frequency? While approaching or when it is going away?
Wave Phenomena:
A. 3.0 × 10–3 rad
B. 2.0 × 10–3 rad
C. 1.3 × 10–3 rad
D. 1.2 × 10–3 rad
Here you go:
http://en.wikipedia.org/wiki/Diffraction#Single-slit_diffraction
http://www.math.ubc.ca/~cass/courses/m309-03a/m309-projects/krzak/index.html
Related to Questions concerning Dopplers Effect and Wave Phenomena
1. What is the Doppler Effect and how does it work?
The Doppler Effect is the change in frequency or wavelength of a wave when the source of the wave is in motion relative to the observer. This means that the perceived frequency or wavelength of a wave will be different depending on the relative motion between the source and the observer. For example, when a car with a siren passes by, the pitch of the siren will sound higher as it approaches and lower as it moves away.
2. What are the applications of the Doppler Effect?
The Doppler Effect has many practical applications. It is used in radar and sonar technologies to determine the speed and direction of moving objects. It is also used in medical imaging techniques, such as ultrasound, to measure blood flow and detect abnormalities in the body. The Doppler Effect is also utilized in astronomy to determine the speed and direction of celestial objects.
3. How does the Doppler Effect apply to light waves?
The Doppler Effect also applies to light waves, which can be observed in the phenomenon known as redshift and blueshift. When an object emitting light is moving away from an observer, the wavelength of the light appears longer, causing it to shift towards the red end of the spectrum (redshift). Conversely, when an object is moving towards an observer, the wavelength appears shorter, resulting in a shift towards the blue end of the spectrum (blueshift).
4. Can the Doppler Effect be observed with all types of waves?
Yes, the Doppler Effect can be observed with all types of waves, including sound waves, light waves, and water waves. However, the effect may be more noticeable with certain types of waves, such as sound waves, because they are easier to detect and measure in everyday situations.
5. How does the Doppler Effect relate to the concept of frequency and wavelength?
The Doppler Effect is directly related to the concepts of frequency and wavelength. As the source of a wave approaches an observer, the frequency of the wave appears to increase, while the wavelength appears to decrease. Conversely, as the source moves away from the observer, the frequency appears to decrease and the wavelength appears to increase. This is due to the compression and expansion of the waves as the source moves towards or away from the observer.
