manal950
- 177
Hi all
can please help me
Decide whether each of these statemtents is true of false
1 ) An on-off temperature controller must have
A ) An error signal input which switches the controller on or off (False )
B ) An output signal to switch on or off the correction element ( true )
2 ) Oscillations of the variable being controlled occur with
on -off temperature controller becuse
A There is a time delay in switching off the correction element
when variable reaches the set value (True )
B) there is a time delay in switching on the correction element
when the variable falls below the set value . (False )
3 ) with a proprtional contoller
A ) the controller output is proportional to the error (True )
B ) the controller gain is proptioal to the error (False )
4 )
A steady state error will not occur when there is a change to
the set value with a control system operating in the mode
A) proportional
B) proportional plus derivative
C)derivative
D) proportional plus integral
The answer is C
5 ) With a controller operating with a derivative control mode
A) the controller output will be constant when the error is constant (False)
B ) the controller output will be zero when there error is constant (True )
can please help me
4 )
A) proportional
C)derivative
The answer is C
