Questions on Rationalizing & Limits: Answers & Explanation
  • MHB
  • Thread starter tc903
  • Tags
    Couple
In summary: It is zero?Here is a table.x,y-1,-6-2,-3-3,-2-4,-3/2-5,-6/5-6,-1-7,-6/7-8,-3/4-9,-2/3-10,-3/5I get $-\infty$, and W|A agrees.
tc903
Hi,
I tried rationalizing the first one but I get zero.
\[\lim_{x\to 3}\frac{\sqrt{19-x}-4}{\sqrt{28-x}-5}\]
\[\lim_{x\to 3}\frac{-x-3}{(\sqrt{28-x}-5)(\sqrt{19-x}+4)}\]
Here is my next question.
\[\lim_{x\to 0^{-}}\left(\frac{3}{x}-\frac{3}{|x|}\right)\]
\(\displaystyle f(x)=\begin{cases}-x, & x<0 \\[3pt] x, & 0\le x \\ \end{cases}\)
\[\lim_{x\to 0^{-}}\frac{6}{x}\]
I will post a picture of this later if the $\LaTeX$ didn't work.
Hello and welcome to MHB, tc903! :D
I tried fixing your $\LaTeX$ and I hope I interpreted things correctly.
For the first one, I suggest trying to rationalize both the numerator and the denominator simultaneously:
\(\displaystyle \frac{\sqrt{19-x}-4}{\sqrt{28-x}-5}\cdot\frac{\sqrt{19-x}+4}{\sqrt{19-x}+4}\cdot\frac{\sqrt{28-x}+5}{\sqrt{28-x}+5}\)
Now simplify...do you now have a determinate form?
tc903 said:
Hi,
\[\lim_{x\to 3}\frac{-x-3}{(\sqrt{28-x}-5)\left(\sqrt{19-x}+4\right)}\]
\[\lim_{x\to 0^{-}}\left(\frac{3}{x}-\frac{3}{\left| x \right|}\right)\]
\[f(x)=\begin{cases}-x&\mbox{ when }& x<0\\
x&\mbox{ when } & x\geq 0\end{cases}\]
I will post a picture of this later if the latex didnt work.
Hi tc903, :)
I edited your LaTeX code to make the expressions visible but I am not sure whether what I have written is what you had in mind. Let us know whether it needs additional changes.
My second question I would assume does not exist but is wrong. I did try rationalizing both the numerator and denominator beforehand. Am I correct?
\[\lim_{{x}\to 3}\frac{\sqrt{28-x}+5}{\sqrt{19-x}+4}=\frac{5}{4}\]
It wouldn't let me edit my previous post. I meant 5/4.
I edited your post to fix the $\LaTeX$ and change your result. That looks good to me. :D
Thanks MarkFL. I was wondering if you can clear something up with the second question though with the absolute value.
What you did in your first post for the second question looks correct to me. You gave the piecewise definition of the absolute value and correctly simplified the limit based on that definition. Now all that is left to do is evaluate the simplified limit. :D
I stated it did not exist, but that is wrong. I substituted zero and that would be make it undefined but that is wrong. It isn't - \infty .
It is zero?
Here is a table.
x,y
-1,-6
-2,-3
-3,-2
-4,-3/2
-5,-6/5
-6,-1
-7,-6/7
-8,-3/4
-9,-2/3
-10,-3/5
I get $-\infty$, and W|A agrees. :D
I should have tried that. I just didnt think it was an option because it didnt say I can put it in their. The question usually asks if the limit exists find it. (type so and so for inifinity or for none exist) It had only chosen one of those. Thanks MarkFL!
FAQ: Questions on Rationalizing & Limits: Answers & Explanation
What is rationalizing and why is it important in math?
Rationalizing is the process of simplifying a radical expression by eliminating the radical from the denominator. It is important in math because it allows us to work with simpler and more manageable expressions, and it also helps us solve equations and inequalities more easily.
How do you rationalize a denominator with a single radical?
To rationalize a denominator with a single radical, you need to multiply both the numerator and denominator by the conjugate of the radical expression. The conjugate is formed by changing the sign between the terms in the radical, for example, if the denominator is √a + b, the conjugate would be √a - b. This will eliminate the radical from the denominator and allow you to simplify the expression.
Can you rationalize denominators with more than one radical?
Yes, you can rationalize denominators with more than one radical. The process is the same as with a single radical, you just need to multiply by the conjugate of each radical term in the denominator. This may result in multiple steps and simplifications, but the end result will be a rationalized expression.
What are the limitations of rationalizing denominators?
Rationalizing denominators can only be applied to expressions with radicals in the denominator. It cannot be used for other types of fractions or expressions. Additionally, the process of rationalizing may result in more complex expressions, so it may not always be the most efficient method for simplifying expressions.
What is a limit in calculus?
A limit in calculus is a mathematical concept that represents the value that a function or sequence approaches as the input or index approaches a certain value. It is used to describe the behavior of functions and sequences near a particular point or as the input or index approaches infinity or negative infinity.
