Questions on the Dirac equation
In summary, the conversation discusses the Dirac equation and its interpretations as a single-particle wave equation and as a field equation. It also touches on the representations of the Lorentz group and their relation to the Dirac field. It is noted that the Dirac fields do not transform under the Lorentz group itself, but rather under a subgroup of it. The conversation also mentions the existence of different representations of the Lorentz group using 4x4 matrices, but notes that they act on different fields than the Dirac field.
Matterwave
328
I must admit that I have never had a great familiarity with the Dirac equation. No matter how many times I study it, I get bogged down in the algebra and never seem to get a good understanding of it. So here's a few questions in my mind at the moment. I am referring here to the Dirac equation as a single particle wave equation (not as a field equation).
1) We have that there are 4 internal states of a spin 1/2 particle, 2 of which correspond to particle with two possible spin orientations, and 2 of which correspond to its antiparticle with 2 possible spin orientations. Does that mean we can have a particle which is a linear combination of particle+antiparticle states? This in my mind would be analogous to a particle which is a linear combination of spin up and spin down for example. If not, then why not? But if so, what is the physical meaning of an particle in a superposition of, for example, electron+positron states? By charge conservation, it seems this should be forbidden. But then again when we first learned QM, we found immediately that strict Energy conservation appears to be broken for linear combinations of different energy states, but that the expectation value of energy is conserved. Is there some analogous "the expectation value of charge is conserved" statement here?
2) Can we transform a particle into its antiparticle via a Lorentz transformation? In my mind, this would be analogous to transforming a spin up along z particle to a spin up along x particle by rotating my x-axis into the z axis. If not, then why not?
3) Since the Lorentz boosts cannot be represented by unitary group of transformations, to construct a probability current and density which remains normalized under a Lorentz boost, we cannot use ##u^\dagger \gamma^\mu u## but instead we use ##\overline{u}\gamma^\mu u## where ##\bar{u}=u^\dagger\gamma^0##. Is this basically modifying the metric on our space from the usual metric to a modified metric where I have to multiply by a gamma matrix in the middle of all inner products? This would seem to, in turn, change our correspondences of kets to bras. The physical state which is dual to ##u## is now ##\overline{u}## and not ##u^\dagger##?
If you want to understand the Dirac equation as a single-particle wave equation, then there is no antiparticle; instead, there are negative energy states of the particle. Superposing states of different energy presents no problem, as usual in quantum mechanics.
If you want to understand the negative-energy states as "really" being antiparticles, then you must abandon the interpretation of the Dirac equation as a single-particle wave equation.
So what about question 2 and 3 then? Can we give a single particle a negative energy simply by making a Lorentz transformation?
No. An orthochronous Lorentz transformation (that is, one that does not involve time reversal) does not change the sign of the energy.
Thanks for the help. I have another question about the Dirac equation.
Deriving the Dirac equation, one finds that there are equivalent representations of the spinors and transformation matrices corresponding to the Lorentz group. The most commonly used ones are the chiral representation, and the standard representation, which are related by a similarity transformation with a unitary matrix.
I don't know very much about representation theory, but there's at least one other representation of the Lorentz group using 4x4 matrices that I know of, namely, the regular Lorentz transformations on 4-vectors in space-time. Why is this representation not used?
These are not representations of the Lorentz group per say. What you're referring to are representations of the Clifford algebra for the Dirac (gamma) matrices ##\{\gamma^{\mu}, \gamma^{\nu}\} = 2g^{\mu\nu}## from which we can define a representation of the Lorentz algebra by ##S^{\mu\nu} = \frac{1}{4}[\gamma^{\mu},\gamma^{\nu}]## which can be easily checked. Now a representation of the Lorentz algebra has to act on some field. The field ##\psi^{\alpha}(x)## that this representation acts on is the Dirac field (here ##\alpha## is a spinor index) i.e. ##\psi^{\alpha} \rightarrow S^{\alpha}_{\beta}\psi^{\beta}(\Lambda^{-1}x)##; here ##\Lambda## is a 4-vector representation of the Lorentz group.
The Dirac fields do not transform under ##\Lambda## they transform under ##S## as defined above; in other words these representations act on different fields (the latter on Dirac fields and the former on vector fields). ##S## and ##\Lambda## are fundamentally different representations. For example ##S## takes ##\psi^{\alpha} \rightarrow -\psi^{\alpha}## under a full rotation whereas ##\Lambda## as usual takes ##A^{\mu} \rightarrow A^{\mu}## under a full rotation (here ##\mu## is a Lorentz index).
As an aside, the 4-vector representation (1/2,1/2) can be built from the spinorial representations (1/2,0) and (0,1/2) of the Lorentz algebra as can the 4-tensor representations and so the spinorial representation is the most fundamental so it's not that it isn't used at all (the photon field transforms under the 4-vector representation) but rather that it applies to vector fields, not spinor fields.
Hmmm, thanks for your answer. I believe you mean that the field transforms as ##\psi^\alpha\rightarrow \exp(i\omega_{\mu\nu}S^{\mu\nu})^\alpha_\beta\psi^\beta(\Lambda^{-1}x)## right? So it seems that representations of the Lorentz algebra using the gamma matrices does not, in fact, exponentiate into the Lorentz group itself...but the simply connected group with the same Lorentz algebra right? Which group is that? I know, for example, for SO(3) that the simply connected group with the same Lie algebra is SU(2), but I don't know what's the case for O(1,3)...su(2)xsu(2)? (That would be my guess)
Well that's for an arbitrary rotation angle; when I said "full rotation" above I meant a rotation by ##2\pi##.
##SL(2,C)##
Ok thanks! :D
It can't be [itex] \mbox{SU}(2)\times\mbox{SU}(2) [/itex], because this one is compact, while the restricted Lorentz group ([itex] \mbox{SO}_{\uparrow}(1,3)[/itex]) isn't.
The covering group of the restricted Lorentz group SO(3,1) is SL(2,C).
A basis for sl(2,C) is the [itex]\sigma^{\mu}= (1, \vec{\sigma})[/itex] so a general element of sl(2,C)can be written as:
[itex] A= x_{0} \sigma_{0} + \vec{x} \vec{\sigma} \in SL(2,C)[/itex]
In matrix form:
[itex]A= [/itex]
[itex]x_{0}+x_{3} , x_{1}-ix_{2} [/itex]
[itex]x_{1}+ix_{2}, x_{0}-x_{3} [/itex]
From which you can take from detA=1:
[itex] (x_{0}+x_{3}) (x_{0}-x_{3} ) - (x_{1}-ix_{2})(x_{1}+ix_{2}) = 1 [/itex]
or that:
[itex] x_{0}^{2}-x_{3}^{2} - x_{1}^{2}- x_{2}^{2} = 1 [/itex]
and here you have that strange "sphere" thing, which gives you the [itex]SO(3,1)[/itex] due to the different signs of the metric...
Related to Questions on the Dirac equation
1. What is the Dirac equation?
The Dirac equation is a mathematical formula that describes the behavior of fermions, which are fundamental particles such as electrons and quarks. It was developed by physicist Paul Dirac in 1928 and is a cornerstone of quantum mechanics.
2. Why is the Dirac equation important?
The Dirac equation is important because it successfully combines two major theories of physics: quantum mechanics and special relativity. It also accurately predicts the behavior of fundamental particles and has been crucial in the development of modern physics.
3. How does the Dirac equation differ from other equations?
The Dirac equation differs from other equations in that it is a relativistic wave equation, meaning it takes into account the effects of special relativity. It also includes spin, a fundamental property of particles, and has both positive and negative energy solutions.
4. Can the Dirac equation be solved exactly?
No, the Dirac equation cannot be solved exactly for all cases. It can only be solved exactly for a few simple systems. In most cases, approximations and numerical methods are used to solve the equation.
5. What are some practical applications of the Dirac equation?
The Dirac equation has many practical applications in modern technology, such as in the development of transistors, lasers, and other electronic devices. It is also used in medical imaging techniques like MRI and PET scans, as well as in the study of particle physics and the behavior of fundamental particles.
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
  • Quantum Physics
