Questions regarding something in Feynman's lectures.
  • Thread starter SrEstroncio
  • Tags
    Lectures
In summary, the conversation discusses a section in Feynman's lectures where he explains the concept of electric charges and the electric field using a mind experiment involving a charged comb and a piece of paper. He then introduces the idea that vibrating electric charges produce a field which has a longer reach than the force associated with simple electrical attraction or repulsion. There is also a discussion on the magnetic field produced by moving charges and the comparison of charges to cork pieces on a pool. The conversation ends with a debate on the efficiency of DC and AC systems in transmitting electricity.
SrEstroncio
62
This isn't quite homework help, although it might seem a little like it.
I was reading my copies of the Feynman's lectures the other day and in volume 1, chapter 2, section 2, "Physics before 1920" he mentioned something which confused me a little: when explaining electric charges and introducing the electric field he sets up a mind experiment in which you shake a charged comb and a little piece of paper, some distance away, moves accordingly, but with a certain delay; then he explains that we then notice something even more interesting, that as we shake the comb we see that the effect of it's charge on the piece of paper falls off more slowly than the inverse of the square of the distance, that is, that vibrating electric charges produce a field which is more far-reaching than the force associated with simple electrical attraction or repulsion.
He follows this up with a metaphor in which he compares the two charges with pieces of cork on a pool (the water being the electric field): we can move one piece of cork by means of moving the other one towards it, thus causing a perturbation in the water which will move the second piece of cork away, even though the effect will be smaller the more distance between the pieces of cork there is; he then adds that by jiggling one piece of cork we can obtain waves whose influence extends very much farther out than the effect of a single movement.
Is he trying to say that only vibrating electric charges produce an electric field? or that the electric field's effect falls of more slowly than the inverse of the square of the distance? I really don't know a whole lot about EM but from what I recall from Resnick's "Physics", charged particles emit a field whether or not they're vibrating, and it's effect also falls off inversely as the square of the distance. I got a little confused and was wondering if someone could clarify what the lectures meant or something.
Sorry for my poor composition skills, by the way.
He's saying that the radiation field generated by an oscillating charge drops off less quickly than the inverse square.
A stationary charge generates the regular r-2 coulomb field.
Charges that are moving also produce a B (magnetic) field. Maybe this helps with EMagnetic wave part?
I believe he's only concerned with the electrical aspects of said oscilating charge, as he briefly explains and dismisses the magnetic part of if as the cause of said effect.
Could you elaborate on this?
I could try!
If you're reading Feynmann's lectures, I would imagine that you're acquainted with Coulomb's law - a stationary charge generates a static electric field proportional to the magnitude of the charge which drops off with the square of the distance:
[tex]E \propto[/tex] [tex]\frac{q}{r^2}[/tex]I think the easiest way to see the generation of a radiation field is to look up the calaculation of the electric field generated by a Hertzian dipole. I can recommend Griffith's "Introduction to Electrodynamics" for this, although I would imagine that Feynman covered it too.
Ah, now it makes sense. From a stationary charge, the force (the electric field) on a test charge falls off proportional to r^2, as dictated by the geometry of the field lines.
From a vibrating charge, the power incident on a test charge (the intensity of the EM wave) also falls off proportional to r^2, as dictated by the geometry of the energy radiation. But this is comparing peaches to avocados, we should return to discussing force: the amplitude of the wave (the electric field or the force the wave produces on a stationary test charge) only falls off proportional to r.
Interestingly this is why we abandoned the original Edison DC grid for the more efficient and easier to propagate Tesla AC system. To achieve similar results a DC system would need gigantic conductors and copper is expensive.
Tesla = Genius
Tesla = Genius
Uh, I don't think that's right. DC is actually more efficient to propagate. Because it doesn't radiate energy away to space, and because it stays high voltage all the time (whereas AC is low voltage for part of its cycle, increasing the resistive losses). The reason we use AC is because it was easy to transform AC voltages (between transmission lines and household devices) using primitive technology, whereas the technology for efficient DC power voltage conversion is more recent.
Related to Questions regarding something in Feynman's lectures.
1. How did Feynman's lectures contribute to modern physics?
Feynman's lectures were a major influence on modern physics, particularly in the fields of quantum mechanics and particle physics. His explanations and insights helped to advance our understanding of these complex theories and continue to shape the way we think about the universe.
2. What made Feynman's lectures unique?
Feynman's lectures were known for their engaging and accessible style, making complex concepts easier to understand for both students and experts. He also used humor and real-life examples to illustrate his points, making his lectures both informative and entertaining.
3. Did Feynman's lectures cover a wide range of topics?
Yes, Feynman's lectures covered a wide range of topics in physics, including classical mechanics, electromagnetism, quantum mechanics, and more. He also discussed philosophical and historical aspects of physics, providing a well-rounded education for his students.
4. How did Feynman's lectures impact the scientific community?
Feynman's lectures inspired many young scientists and helped to shape the way physics is taught and understood. His groundbreaking work and unique teaching style continue to have a lasting impact on the scientific community.
5. Can anyone understand Feynman's lectures, even without a background in physics?
While Feynman's lectures do cover complex concepts, his explanations and examples make them accessible to anyone with an interest in physics. However, a basic understanding of mathematics and science is helpful in fully comprehending the material.
  • Science and Math Textbooks
