Questions regarding sputtering machines, their magnetrons, and etch process
In summary: Chapman's Glow Discharge Processes is a classic in this area. Very understandably written, with all the fundamental background that never makes it into the manuals. Also very good: Vossen and Kern's Thin Film Processes and Campbell's The Science and Engineering of Microelectronic Fabrication. I think you'd get a kick out of reading some of these, since you have practical experience.Thanks for the reference.
Mike_In_Plano
702
35
Hello,
Years back, I used to work with a sputtering machine, but I never really understud some of the activities within the machine.
One of the things that puzzled me was why the target was to be eroded, while the surrounding metal structure that held it in place and formed the lid, was not. I could see that the targets were eroded in the center and in a concentric ring. Are these the areas for the poles of the magnet?
The other thing that puzzled me was etching. The substrate didn't seem to have anything magical about it that it would suddenly start loosing material. There was an electrical switch on the machine and a different gas source, that was manually switched. There was a shutter that covered the target, which I presume was to prevent plating the target with material from the substrate? But what as to what was really going on, I'm clueless.
Finally, I guess I'm curious about the impedance that the target typically represents. We had 250 watt RF source, and it went into a matching network on the back of the sputtering chamber. It took a bit of jiggling about of the load / resonance at the transmitter to get a good plasma in the chamber, and typically, the "sweet spot" would shift a little between firing and optimal matching.
Anyway, I know these are a lot of specific questions, but the machine always was of great interest to me, and none of the documentation was very detailed. It would make me a happier man to have some of these mysteries resolved.
Thanks,
Mike
However, the book is fairly expensive, and not to be found in my local libraries. Does anyone have a cheaper suggestion. Particularly regarding the etch process. This question has bugged me from day one. Do they apply a - voltage to the substrate to encourage stripping?
Mike
Related to Questions regarding sputtering machines, their magnetrons, and etch process
1. What is a sputtering machine and how does it work?
A sputtering machine is a device used in the manufacturing of thin films on various materials. It works by using a high-energy plasma to bombard a target material, causing atoms to be ejected from its surface and deposit onto a substrate material.
2. What is a magnetron and what role does it play in sputtering machines?
A magnetron is a type of cathode used in sputtering machines to create the plasma needed for the sputtering process. It consists of a negatively charged central cathode surrounded by a positively charged anode, with a magnetic field applied to help direct the electrons towards the target material.
3. How does the etch process work in sputtering machines?
The etch process in sputtering machines involves using a reactive gas, such as oxygen, to react with the sputtered atoms and remove them from the target material. This allows for precise control of the thickness and composition of the deposited film.
4. What are the common applications of sputtering machines?
Sputtering machines are commonly used in the production of electronic devices, such as computer chips and solar panels. They are also used in the manufacturing of architectural glass, decorative coatings, and hard coatings for tools and machine components.
5. How can I troubleshoot issues with my sputtering machine?
If you are experiencing issues with your sputtering machine, it is best to consult the manufacturer's manual or contact their technical support for assistance. Common troubleshooting steps may include checking for gas leaks, cleaning the vacuum chamber, and ensuring proper power supply and gas flow rates.
