- #36
- 23,370
- 5,733
This has nothing to do with whether the container has fixed volume. The important parameters are the pressure and the temperature, and whether there is head space present. In the latter case, there is head space above the water/ice mixture, but with no air present. Here are the equilibrium cases of interest (please examine and compare them carefully):Red_CCF said:For the case of a pressure of 1atm applied from a piston, in the phase diagram in my OP, I believe the melting point is 0C and 1atm. In the case of a fixed volume container, the melting/triple point is at 0.01C with the vapour pressure at 0.00611bar.
1. Piston applying pressure of 1 atm at 0 C, no air present, no head space present.
2. Piston applying pressure of 0.00611 bar at 0.01C, no air present, head space present, water vapor present in head space at 0.00611 bar.
3. Piston applying pressure of 1 atm at 0 C, head space present, air present in head space, with total pressure of water vapor and air in head space equal to 1 atm.
4. Piston applying pressure between 0.00611 bar and 1 atm, temperature between 0.01 and 0 C, head space present, air present in head space, with total pressure of water vapor and air in head space between 0.00611 bar and 1 atm.
No. See my previous answer above.Essentially I see that the water is at two different thermodynamic states. My impression is that adding an ideal gas/air to increase the total pressure to 1atm for the fixed volume case does not alter the melting point and that only when the total pressure is extremely high does the melting point begin to converge to 0C as in the piston case. Is correct?
I'm confused by the use of the equation. In my calculation I assumed a piston-cylinder at 50atm and 0C, which from the phase diagram is only liquid-solid (no vapour phase), so I'm confused on how the equilibrium vapor pressure comes in.
Please bear with me. This is only the first step in the calculation. The vapor pressure of ice at 0C will give you the fugacity of water at 0C and that pressure. We then take that number and continue the calculation to get the fugacity of ice and liquid water at 0C and 50 atm.
Chet
