Why Is LCDM Preferred Over VSL in Modern Cosmology?
  • Thread starter fasterthanjoao
  • Tags
    Lcdm
In summary: So at this point the evidence is very weak that there is a real physical effect due to a changing alpha. On the other hand, if the evidence for a changing alpha is weak, then it's very difficult to argue that there is no effect.There have been papers in the last few years looking for variations in the fine structure constant using different methods, but so far none of them have been able to find a reliable signal. There is still some work to be done in this area, but at the moment it's very uncertain if there is a real effect or not.There is also a problem with the theory of general relativity called the strong energy condition. This condition states that the energy of a system must be constant
fasterthanjoao
731
A couple of things to start with. I'm going to put forward some questions I need help understanding surrounding VSL. I'm not anti-LCDM or against inflation/etc. I'm just interested in the mechanisms of setting up a 'new' theory (I'm aware Einstein delved into VSL, and subsequently disregarded, whilst formulating GR).
I'm also a finishing undergraduate student. Whilst I have some questions of my own, I would greatly appreciate input of any kind - questions of your own (not necessarily things you don't know, just things about the theory I should look up on my own - problems/inconsistancies etc.) or even just reasons you would disregard the possibility.
My purpose isn't to find out whether VSL is correct or not, I'm more interested in why there seems to be such a mass popularity for LCDM (I know the definition of standard theory would be one that is accepted by most people) and if the reasons for the rejection of alternatives like VSL is purely scientific or holds some tranditional bias as well.
I'll start off with the possibility of a varying-fine-structure constant (alpha). I don't know what the current stance is, and I'm trying to catch up on years of papers but from what I've seen:
- There are four main methods to investigate a changing alpha.
- Three of these methods have yeilded 100%+ error bars, so are inconclusive.
The fourth (J.D. Barrow) looks for small changes in the absorption of quasar light by gas clouds between us and the subject. The separation of different lines is analysed, allowing any combination of lines to be investigated meaning there should be a good chance for accuracy and precision. (The main advantage seems to be that we can predict where the spectral lines should be if alpha is varying, so if we find the lines in these new, adjusted positions then...) I would like to know if there has been any recent papers on this subject, or anything anyone feels is particularly noteworthy about this method.
Secondly, VSL interprets the possibility of a varying alpha as a varying of the inverse of the square of the speed of light. Lorentz invariance and covariance is broken - which I assume means there is a preferred frame for the formulation of physical laws? Is this valid? and if so, what physical meaning does it have?
Also, Inflation seems to violate the strong energy condition - and VSL violates Lorentz invariance. Is there any reason either of these two violations would be preferable?
There are a couple of problems with VSL I'd like to discuss also:
There is a well known issue with conservation of energy (I assume this is still present, I've managed to only digest a handful of papers on the subject and am grateful of any guidance) since it depends on the speed of light. Is, quite simply, conservation of energy violated? or is there another mechanism to avoid this? In fact, is there any reason to even assume that conservation of energy should apply to the whole Universe over vast periods of time?
And, just quickly, there's a small part in (J.D Barrow; Physical review D, Vol 59, 043515) about a problem with black holes. The issue lies with the raduis of a black hole - which depends on the speed of light. Differentiating R to find a rate of change when including a varying C shows that if c is falling (as required to solve the horizon, flatness etc) then the radius of black holes will increase significantly as the Universe ages.
I am grateful for any input on this subject, be it problems that I might not be considering or general thoughts.
Space news on Phys.org
Now I just don't believe no-one has an opinion on this :wink: I'm not looking for unadulterated expert/professional guidance, just some thoughts!
If you search for papers by John Webb of the University of New South Wales, Michael Murphy etc, you will find papers on the quasar absorption line methods.
The problem with the QSO absorption method for alpha is that the results from Keck indicated that in the past alpha was lower, but there was no function form to this, i.e. it just appeared that on average absorption systems probed with this method had a lower alpha than that measured in labs on Earth. This makes some small systematic effect a likely candidate for the explanation. Michael Murphy spent a lot of time looking for possible systematics but nothing was found that could explain it.
The real problem though is that results using the VLT have not matched the results from Keck. Other groups have also done similar analysis with different data and have not found the same effect as the UNSW group. I would say that varying alpha isn't dead, but the evidence for it is underwhelming.
Related to Why Is LCDM Preferred Over VSL in Modern Cosmology?
1. What is VSL and LCDM?
VSL stands for variable speed of light and LCDM stands for Lambda-Cold Dark Matter. They are two competing cosmological models that attempt to explain the expansion of the universe.
2. What are the differences between VSL and LCDM?
The main difference between VSL and LCDM is that VSL proposes that the speed of light was much faster in the early universe, while LCDM assumes a constant speed of light. VSL also suggests a different mechanism for the expansion of the universe compared to LCDM.
3. Which model is currently accepted by the scientific community?
LCDM is currently the accepted model by the majority of the scientific community. It is supported by a wide range of observational data and has successfully predicted many observations of the universe.
4. What are the potential implications of VSL being true?
If VSL is found to be a more accurate model than LCDM, it would challenge our current understanding of the universe and the laws of physics. It could also have implications for other areas of science, such as particle physics and cosmology.
5. What ongoing research is being conducted on VSL vs LCDM?
There is ongoing research in theoretical and observational cosmology to test the predictions of both VSL and LCDM. Scientists are also looking for new evidence and data that could provide insight into which model is more accurate.
  • Beyond the Standard Models
  • Astronomy and Astrophysics
  • Materials and Chemical Engineering
