Quick Easy Question, takes 5 seconds
  • Thread starter Fusilli_Jerry89
  • Tags
    Seconds
In summary: the right way is through the solubility product or equilibrium constant (as explained above by c-tree).
Fusilli_Jerry89
159
How does the solubility of BaSO4 in a solution of Na2SO4 compare to its solubility in pure water?
I said that it is greater in the water. I don't know if I'm right, or how to explain it however. I see that if those two compounds reacted, then the products would be the exact same as the reactants. Therefore there would be no dominant charges in gettting the reaction to move forward. Is this part of it, or all of it, help me out please.
with solubility, remember that like dissolves like (in terms of intermolecular forces)
BaSO4 is quite similar to Na2SO4 but quite different from H2O (water has hydrogen bonding) so BaSO4 will be less soluble in water
to understand why like dissolves like, consider a flask with two kinds of molecules, A and B. On the top layer is B molecules, on the bottom layer is A molecules. will they mix up, or stay apart (are they miscible, or immiscible, respectively)?
well let's consider what happens when an A molecule moves into the region of B molecules... if the attraction between A molecules is much stronger than the attraction between an A and a B molecule, then the A molecule will get sucked back into the A region because it is attracted to all the other A molecules, and it is immiscible.
however, if the A molecule is attracted to the B molecules at about the same strength as it is attracted to its own kind, nothing will stop them from mixing
so, whenever faced with this kind of question, consider which molecules have which attractive forces (and how much of each force) and compare
the three attractive forces you will want to consider, for each molecule, are: hydrogen bonding, london forces, and dipole dipole forces
for: BaSO4 <---> Ba+2 + SO4-2
Keq = [Ba+2]*[SO4-2]/ [BaSO4]
You see that the equilibrium constant is related to the concentration of both Barium and sulfate in solution divided by the concentration of Barium Sulfate in solid state (a constant value). Adding sulfate from sodium sulfate increases the concentration of [SO4] on the right. To reestablish equilibrium, The reaction proceeds from right to left so that the product of barium and sulfate remains constant. This is a description of LeChatlier's Principle.
Another form for this solubility equilibrium is the Solubility Product Constant (Ksp).
Ksp = [Ba+2] * [SO4-2]
To remain in equilibrium, the product of these two species must equal to the Ksp. Increase one and the other is decreased. Lower one and the other is increased.
The value for Barium Sulfate is 1.08 X 10-10, a very small number (that is nine zeroes in front of the 1).
Adding Na2SO4 to a solution of BaSO4 at equilibrium adds [SO4-2] to the above expression and thus the concentration of [Ba+2] must change to remain a equilibrium.
qwedsa: This is incorrect - for one thing "similar" and "different" are ill-defined, but that's not all.
This not how you want to answer this question, and furthermore, it is incorrect as it completely ignores any entropic contribution to the free energy.
That is definitely not the right way to approach the kind of question raised by jerry. The right way is through the solubility product or equilibrium constant (as explained above by c-tree).
Google common ion effect (after reading chemisttree answer :wink: ).
i defined them in terms of the strength of intermolecular forces. not ill-defined at all
yes, I'm sorry, i forgot that we are dealing with ions, not molecules
well it was nearly word for word from the solubility section of my chem textbook, it's not incorrect
again, i forgot about the ion issue (dissociation). but for any question dealing with solubility of molecules (as opposed to ions), my method IS how you would address the problem
OK so as i understand, it is more soluble in water? I see that with water it's ksp is just [Ba][SO4], but with the equation: BaSO4 <---> Ba + SO4; when you add Na2SO4, the SO4 conc. would increase, and the equilibrium would shift left. Now, this means that the Ksp would decrease, therefore its less soluble in water...right?
Ksp won't change (it is a constant), the concentration of barium in solution will change.
When barium sulfate dissolves, it produces barium and sulfate ions. The process, at equilibrium, is denoted as the reaction:
BaSO4(s) <----> Ba+2 + SO4-2
This expression evokes the concept that barium and sulfate ions are continually being dissolved from the solid barium sulfate and barium sulfate is continually being precipitated from a solution containing barium and sulfate ions. At equilibrium these two processes (dissolution and precipitation) occur at exactly the same rate and to the observer it appears as though nothing further is happening... until you add something like sodium sulfate and disturb the equilibrium. After a time, equilibrium is reestablished such that the expression for Ksp is valid.
You can think of the solubility of BaSO4 as the concentration of barium in solution. The more barium in solution, the more soluble BaSO4 must be. If something decreases the concentration of barium in solution, the less soluble BaSO4 must be.
I meant trial Ksp, not Ksp.
Qwedsa's comments are valid for a so-called inert salt. If a salt that contained no common ions were added to water, the solubility of BaSO4 could be increased. The phenomenon is referred to as "Salting In".
If the salt contains a common ion the Ksp argument is applied.
FAQ: Quick Easy Question, takes 5 seconds
1. What is a "Quick Easy Question, takes 5 seconds"?
A "Quick Easy Question, takes 5 seconds" is a commonly used term in the scientific community to refer to a simple and straightforward question that can be answered in a short amount of time.
2. Why are "Quick Easy Questions, takes 5 seconds" important in science?
Quick Easy Questions are important in science because they allow for a quick and efficient exchange of information. They can also help to clarify important concepts and ideas, leading to a better understanding of a particular topic.
3. How do scientists come up with "Quick Easy Questions, takes 5 seconds"?
Scientists come up with Quick Easy Questions by breaking down complex concepts into smaller, more manageable pieces. They also use their knowledge and expertise to identify the most important and relevant information to ask about.
4. Can "Quick Easy Questions, takes 5 seconds" lead to significant scientific discoveries?
Yes, Quick Easy Questions can lead to significant scientific discoveries. By asking simple and focused questions, scientists can uncover new information or connections that may have been overlooked before. These discoveries can then lead to further research and advancements in the field.
5. How can I use "Quick Easy Questions, takes 5 seconds" in my own scientific research or studies?
You can use Quick Easy Questions in your own scientific research or studies by breaking down complex ideas or concepts into smaller, more manageable questions. This can help you to gain a better understanding of the topic and potentially lead to new discoveries or insights.
