Quick pH calculation - Please verify
In summary, the conversation is about calculating the new pH of a solution after adding sulfuric acid to a solution of sodium hydroxide. The initial pH of the solution is 12.50 and after adding the acid, the new pH is 11.21. The calculation involves determining the limiting reagent and the remaining amounts of hydroxide and sulfate ions.
alingy1
325
Quick pH calculation -- Please verify
A 50.0 mL aqueous solution of sodium hydroxide has a pH of 12.50. If 36.00 ml of 0.0200 mol/L sulfuric acid is added to this sodium hydroxide solution, what will be the new pH of the resulting solution? Assume that the temperature stays constant at 25C, and that the volumes are perfectly additive.
50ml=0.05L
0.00158 mol OH- initially.
0.00072 mol H2SO4
Entire consumption of H2SO4(limiting reagent).
0.00086 mol OH- left.
0.00072 mol HSO4- left.
Entire consumption of HSO4-:
0.00014 mol OH- left.
Volume total=86 ml.
ph=11.21
Makes sense?
Looks OK.
How did you do all of it?
Related to Quick pH calculation - Please verify
1. What is the purpose of a "Quick pH calculation"?
The purpose of a "Quick pH calculation" is to determine the pH of a solution, which is a measure of its acidity or basicity. This can be useful in various scientific experiments and processes.
2. How is pH calculated?
pH is calculated by taking the negative logarithm of the concentration of hydrogen ions in a solution. The formula for pH is pH = -log[H+], where [H+] represents the concentration of hydrogen ions in moles per liter.
3. What is the range of pH values?
The range of pH values is from 0 to 14. A pH of 0 is considered highly acidic, while a pH of 14 is highly basic. A pH of 7 is considered neutral, meaning the solution is neither acidic nor basic.
4. How accurate is a "Quick pH calculation"?
The accuracy of a "Quick pH calculation" depends on the method and tools used. It is important to use accurate measurements and appropriate equipment to obtain a precise pH value. Additionally, external factors such as temperature can also affect the accuracy of the calculation.
5. How often should pH calculations be verified?
The frequency of verifying pH calculations depends on the specific experiment or process being conducted. In general, it is recommended to verify pH calculations at regular intervals and whenever there are significant changes in the solution being tested.
10K
