Quick Q: Is direction of velocity relevant in conservation?
In summary, the concept of energy conservation in collisions does not involve angles, as kinetic energy calculations only consider the magnitudes of velocities. The dot product of a vector with itself produces a scalar that depends only on the magnitude, and this is why the direction of velocity does not affect energy conservation. In cases of elastic collisions, energy is conserved, while inelastic collisions involve the transfer of energy to other forms.
Samei
33
: [/B]I just have a quick question about direction of velocity in solving for energy conservation problems. Since energy has no direction, do different angles ever affect the outcome? Like say in a collision where a truck hits three other vehicles and sends all three in different directions. The resulting velocity on each would be lower since it has direction (i.e., v*cos(45)), would it not? And so, how can energy conservation account for this?
I apologize if this is a very basic question. I'm just curious.
: [/B]Conservation of Energy: KE + PE = KE + PE
: [/B]Since this is more of a conceptual question, I don't really have an attempt.
Angles are involved with momentum.
Kinetic energy calculations do not include angles, just the magnitudes of the velocities of bodies. Major vehicle collisions would usually not conserve kinetic energy, most result in vehicle remodellng and this soaks up energy.
I almost forgot about magnitudes. That should explain it. Thanks!
Are you sure? As NascentO posted, KE is not much use in collisions. You need to work with momentum instead, and that has direction.
E.g. consider a head on collision between two cars of the same mass and same initial speed, compared with a collision at right angles.
This is when elastic and inelastic collisions comes into play, right?
Energy is conserved only in elastic, so it is applied there.
I was just curious how the angles "disappear" when I use it in energy conservation. My teacher did not include them in his calculations, and I figured at first he was just simplifying the problem because he was in a rush. But the book does the same thing. Then, it got me thinking how the conservation laws ever account for the fact that the cars in a collision can be thrown in different directions.
KE is ##\frac 12 m \vec v.\vec v = \frac 12 m |\vec v|^2##. The dot product of a vector with itself produces a scalar which only depends on the magnitude of the vector.
I think that's what I forgot. The vector already includes the direction. So then the magnitude is all accounted for.
Thanks again for clarifying! :)
FAQ: Quick Q: Is direction of velocity relevant in conservation?
Is the direction of velocity important in conservation?
Yes, the direction of velocity is an essential component in the conservation of energy and momentum. In fact, the conservation laws only apply when considering the direction of velocity.
How does the direction of velocity affect conservation of energy?
The direction of velocity determines the direction of the force and therefore the work done on an object. This work is what contributes to the change in the object's kinetic energy, which is a crucial aspect of energy conservation.
Does the direction of velocity have an impact on momentum conservation?
Yes, momentum is a vector quantity that includes both magnitude and direction. Therefore, the direction of velocity plays a significant role in the conservation of momentum. In an isolated system, the total momentum before and after a collision must be equal in both magnitude and direction.
Can an object have a negative velocity and still conserve energy?
Yes, an object can have a negative velocity and still conserve energy. The direction of velocity does not affect the total amount of energy in a system, only the direction in which it is moving.
Why is it important to consider the direction of velocity in conservation?
The direction of velocity is important in conservation because it helps us understand the behavior and interactions of objects in a system. It allows us to accurately calculate and predict the outcomes of collisions and other events within the system.
