Quick Question about emitted radiation and Geiger counter accuracy
In summary, the conversation discusses the amount of gamma radiation emitted by a human body due to radioactive decay of K40 atoms. It is estimated that 240 Bq (Becquerel) of gamma rays escape the body every second, which raises the question of whether this could be detected by a geiger counter and potentially affect its accuracy. It is concluded that the emitted radiation is considered a part of background radiation and can be detected by the geiger counter, but it would only contribute to a small fraction of the overall counts. The conversation also touches upon the importance of background measurements and the use of shielding to deal with all sources of background radiation. Additionally, facts about K40 decay and the emission of beta and photon products are provided.
Abu
39
Hi everyone.
I read from:
https://www.nucleonica.com/Applet/NaturalRA/Button5/page5.html
that inside the human body, 4400 of K40 atoms disintegrate every second through radioactive decay. Of this decay, 11% (480) results in gamma radiation, and 50% of that 11% (240) escapes the body.
My question is that since your body is emitting 240 Bq every second, if you stood next to a geiger counter, would the geiger counter detect your radiation? Would that be a source of error when using the counter?
Or is it so insignificant that it is negligible? Because the 240 Bq would be divided since the radiation is spreading in all directions from yourself, and the geiger would take only a small fraction of that?
Thank you!
Yes, the 240 estimated gamma rays that escape the body are emitted in all directions and only a small fraction of them will enter the counter. You should also consider the efficiency of the counter; not all gamma rays entering the counter result in a "click".
Likes Abu
Once in a while it will trigger a Geiger counter. But so does everything else. The floor, the walls, ... even the material of the Geiger counter itself. This is natural background that has to be taken into account for measurements of low activity.
Likes Abu
Ah okay, so it's part of the background radiation technically. Thank you two very much!
It doesn't have to be. You can record background counts with and without you in the room and see if your presence makes a difference.
Ah, the good old existential question.No, seriously: Background measurements should be done under the same conditions as the measurements with source, if it is relevant this includes the same people nearby.
Abu said:
Hi everyone.
I read from:
Thank you!
"My question is that since your body is emitting 240 Bq every second, if you stood next to a geiger counter, would the geiger counter detect your radiation? "
Definitely.
Would it be a source of error? Again: Definitely.
We spend a great deal of time and money on complex shielding to deal with all sources of background radiation! The more sensitive is your sensor, the more mass quantity and complex the shield needs to be.
Will your bones affect a CDV-700 Civil Defense Geiger Counter- no not really, it's not sensitive enough, but a great deal of the counts it gives with no radioactive sample present do come from the tons of K-40 in the soil surrounding your location.
For the record some facts;
K-40 decays 89% of the time by Beta-minus Emission Decay eventually yielding a stable Ca-40 daughter atom,
while 11% of the time K-40 decays by EC (Electron Capture) Decay, eventually yielding a stable Ar-40 daughter.
Beta Emission Products: K-40>Ca40 Decay
Maximum Average
Fraction Energy(MeV) Energy(Mev)
0.893300 1.311600 0.508540
Photon Emission Products: K-40 >Ar-40
0.009376 0.002958
0.106700 1.460800
1460 keV is rather strong among elemental Gamma Rays, and is a major constituent of earthly "background" radiation. Since it is so prevalent everywhere on earth, it is used as a key calibration marker for Nuclear Metrology calibrations.
Notice the stray 0.002958 MeV photon in the chart. This is
actually a K-alpha (K-a) Chracteristic X-Ray of 2.96 keV generated in the K-a electron shell as the emitted 1460 keV leaves and excites the K-a electron out of its shell. When it is replaced by another electron from a higher shell, that electron emits an energy equivalent to its orbital binding energy.
The 1460 keV (1.46 MeV on the chart above is the IT (Isomeric Transistion) Gamma Ray that is emitted by the excited daughter nucleus, Ar-40.
Thanks
George Dowell
For what it is worth the contribution to the radiation survey count rate from the surveyor is of the order of 0.3 cpm. assuming a solid angle for the detector of 0.02 strd ( detector intercepts only about 0.2% of gammas) and an intrinsic efficiency of 1% and neglecting any absorption or scattering by the body or inverse square law corrections for a non point source.
So unless you are performing a very low activity measurement where your presence would affect the results you need not be concerned. Additionally if you were performing such a measurement you would not be using GM counter.
Likes geoelectronics
100% Correct, you would be using a whole body counter. Here are 3 at the school for nuclear reactor operators, pictured with my assistant Mat Hazard getting his thyroid scan, whole body, and deep chest scans before going home for the day. These are all large volume, highly shielded Gamma Scintillator counters.
Thyroid scanner, tests for concentration of radioiodine in the thyroid, the natural biological sponge for iodine (I had to get one every day when doing certain tasks not to mention the wearing ring film, the TLD, the graduated chest film and the two ionization chamber dosimeters)
https://www.qsl.net/k/k0ff/Nuclear_...owell/ATC July 09/MAT GETS Thyroid Scan 1.jpg
https://www.qsl.net/k/k0ff/Nuclear_Physics_101_By_George_Dowell/ATC July 09/DIY WBS Open1.jpg
Here Mat sits in a heavy lead chair facing a very large disc of lead shielding with a hole in the middle for the scintillator:
https://www.qsl.net/k/k0ff/Nuclear_Physics_101_By_George_Dowell/ATC July 09/MAT GETS WBS 1.jpg
and same scanner from the rear, looking through the lead shield before installing the sensor:
https://www.qsl.net/k/k0ff/Nuclear_Physics_101_By_George_Dowell/ATC July 09/MAT GETS WBS 2.jpg
These can read you bone's natural radiation, plus anything unusual.
George Dowell
Likes gleem
Related to Quick Question about emitted radiation and Geiger counter accuracy
What is emitted radiation?
Emitted radiation refers to the release of energy in the form of particles or waves from a source. This can include alpha, beta, and gamma rays.
How does a Geiger counter measure radiation?
A Geiger counter uses a gas-filled tube to detect the presence of radiation. When radiation passes through the tube, it ionizes the gas and creates an electrical pulse, which is then amplified and counted by the instrument.
What factors can affect the accuracy of a Geiger counter?
The accuracy of a Geiger counter can be affected by several factors, including the type and strength of the radiation being measured, the distance between the source and the detector, and the condition and calibration of the instrument.
Can a Geiger counter measure all types of radiation?
No, a Geiger counter can only detect and measure certain types of radiation, such as alpha, beta, and gamma rays. It cannot detect other forms of radiation, such as X-rays or neutrons.
How can I ensure the accuracy of my Geiger counter readings?
To ensure the accuracy of your Geiger counter readings, it is important to regularly calibrate and maintain the instrument, use proper shielding and precautions when handling radioactive materials, and compare readings with other radiation detection devices.
