Quick Question about throwing a ball vertically
  • Thread starter Thread starter iBill
    Ball
When throwing a ball vertically, the initial velocity of the ball matches the final velocity of the arm at the moment of release. However, the compressibility of the ball complicates this, as it compresses against the hand during acceleration. Upon release, the arm decelerates, raising questions about the energy transfer involved in compressing the ball. It is unclear whether the energy used to compress the ball contributes to its velocity upon launch or is dissipated during the arm's motion. Experimenting with a softly inflated balloon can help illustrate these dynamics.
iBill
If I were to throw a ball vertically upward, would the initial velocity of the ball be the same as the final velocity of my arm?
if by final you mean the second the ball leaves your hand, yes
Yes that is what I meant, thx.
Maybe not so simple - a ball is compressible - so as you accelerate the ball you will compress the ball's side nearest your hand. As the ball leaves your hand your arm must have been decelerating - or presumably the ball wouldn't have left your hand. The question is what happened to the energy you used to compress the ball on acceleration - did it give a kick to the ball which was decompressing on launch or was it already recovered somewhere in your arm motion before the ball left your hand? I don't know :( Try with a softly inflated balloon to see if you can see or feel what happens on release.
Hello everyone, Consider the problem in which a car is told to travel at 30 km/h for L kilometers and then at 60 km/h for another L kilometers. Next, you are asked to determine the average speed. My question is: although we know that the average speed in this case is the harmonic mean of the two speeds, is it also possible to state that the average speed over this 2L-kilometer stretch can be obtained as a weighted average of the two speeds? Best regards, DaTario
Thread 'Beam on an inclined plane'
Hello! I have a question regarding a beam on an inclined plane. I was considering a beam resting on two supports attached to an inclined plane. I was almost sure that the lower support must be more loaded. My imagination about this problem is shown in the picture below. Here is how I wrote the condition of equilibrium forces: $$ \begin{cases} F_{g\parallel}=F_{t1}+F_{t2}, \\ F_{g\perp}=F_{r1}+F_{r2} \end{cases}. $$ On the other hand...
I know that mass does not affect the acceleration in a simple pendulum undergoing SHM, but how does the mass on the spring that makes up the elastic pendulum affect its acceleration? Certainly, there must be a change due to the displacement from equilibrium caused by each differing mass? I am talking about finding the acceleration at a specific time on each trial with different masses and comparing them. How would they compare and why?
