Quick question of Einstein Field Equations
In summary, Einstein Field Equations (EFE) state that: -R_{\mu\nu} - \frac{1}{2}g_{\mu\nu}R = - 8\piGT_{\mu\nu} -R_{\mu\nu} - \frac{1}{2}g_{\mu\nu}R + g_{\mu\nu}\Lambda = \frac{8 \pi G}{c^4}T_{\mu\nu} -8\piT_{\mu\nu} = G_{\mu\nu}
Allojubrious
61
I have seen and read a few different versions of the Einstein field equations (EFE). For example; R[itex]_{\mu\nu}[/itex] - [itex]\frac{1}{2}[/itex]g[itex]_{\mu\nu}[/itex]R = - 8[itex]\pi[/itex]GT[itex]_{\mu\nu}[/itex] , R[itex]_{\mu\nu}[/itex] - [itex]\frac{1}{2}[/itex]g[itex]_{\mu\nu}[/itex]R + g[itex]_{\mu\nu}[/itex][itex]\Lambda[/itex] = [itex]\frac{8 \pi G}{c^4}[/itex]T[itex]_{\mu\nu}[/itex] , and 8[itex]\pi[/itex]T[itex]_{\mu\nu}[/itex] = G[itex]_{\mu\nu}[/itex]
So which one is the true equation?? And if you could explain why they're different that would be great!
Thanks,
Al
Yes, and?
Also, LaTeX may be useful.
[tex]R_{\mu \nu} - \frac{1}{2} g_{\mu \nu} R = - 8 \pi G T_{\mu \nu}[/tex]
Is written as:
Code:
Though usually I think I've seen the right hand side as plus instead of minus.
All three are correct. The first is the normal EFE. The second is the EFE with a cosmological constant. So, the first is the second with a vanishing cosmological constant. In the third, the left side is written as the Einstein tensor. The left side of the EFE collectively describes the curvature of space-time, so that's what the Einstein tensor does. It's just a briefer notation.
EDIT: Also, in the last one, Newton's constant is set equal to 1 (the G on the right hand side in the other equations), to make the equation look nicer.
Thank you Mark M your answer is extremely helpful. But why is the speed of light (c) included in the second EFE with the cosmological constant?
That's the proper way to write it. Similar to the way the third equation set G = 1 so that it disappeared, the first and third equations set c = 1 so that it drops out of the equation.
Also, I forgot to mention why the first has a minus sign on the right. That's a consequence of the sign signature. In relativity, since time is treated as another dimension in space-time, it must be distinguished from the three dimensions of space. Either you make the time coordinate of the metric negative, so that the metric reads [tex] ds^{2} = -dt^{2} + dx^{2} + dy^{2} + dz^{2} [/tex] or leave the time coordinate positive, and make spatial coordinates negative [tex] -ds^{2} = dt^{2} - dx^{2} - dy^{2} - dz^{2} [/tex] this first is called the mostly plus signature (-+++) and the latter is called mostly minus (+---). The second equation is using a different signature than the other two.
That just means that that equation doesn't implicitly take [itex]c=1[/itex] or [itex]G=1[/itex]. It's common in relativity to do both just to reduce the number of constants running around for theoretical work, but putting them back in can be useful when an actual numerical calculation is being performed.
[itex]R_{\mu\nu}-\dfrac{1}{2} g_{\mu \nu} R +\Lambda g_{\mu \nu} = \dfrac{8\pi G T_{\mu \nu}}{c^4}[/itex]
Alright well thank you, that answers my questions! Thanks all!
Thanks,
Al
Related to Quick question of Einstein Field Equations
1. What are Einstein Field Equations?
Einstein Field Equations are a set of ten equations in Einstein's theory of general relativity that describe how gravity works in the universe. They relate the curvature of spacetime to the matter and energy present in that spacetime.
2. Who came up with the Einstein Field Equations?
The Einstein Field Equations were developed by Albert Einstein in 1915 as part of his theory of general relativity.
3. What is the significance of the Einstein Field Equations?
The Einstein Field Equations are significant because they provide a mathematical framework for understanding the relationship between matter, energy, and gravity in our universe. They have been tested and verified through various experiments and observations, and are considered to be one of the most accurate theories of gravity.
4. How do the Einstein Field Equations affect our understanding of the universe?
The Einstein Field Equations have greatly impacted our understanding of the universe by providing a deeper understanding of how gravity works and how it affects the behavior of objects in the universe. They have also helped to explain phenomena such as black holes, gravitational waves, and the expansion of the universe.
5. Are the Einstein Field Equations still relevant today?
Yes, the Einstein Field Equations are still highly relevant and widely used in modern physics. They have been instrumental in the development of theories such as cosmology and the study of the early universe. They are also used in practical applications such as GPS systems, which rely on the equations to accurately calculate time dilation caused by gravity.
