Quick question on a one-dimesnional motion problem
  • Thread starter sk218
  • Tags
    Motion
In summary, a ball is dropped from a window and strikes the ground with speed v. A second ball is thrown upward from the ground with the same initial speed v. The question is whether the balls pass each other at the halfway point between the window and the ground, above this point, or below this point. After considering the acceleration of the balls and drawing a graph, it is determined that they meet 3/4 of the way up and have velocities of -1/2v and 1/2v at that point. The physics teacher and book claim that the balls meet at the midpoint between the ground and the roof, but this is incorrect. The general case for the distance of the balls at time tf is found and compared
So, which letter is right?
  • (a): at the halfway point
    Votes: 0 0.0%
  • (b): above the halfway point
    Votes: 0 0.0%
  • (c): below the halfway point
    Votes: 0 0.0%
  • Total voters
sk218
Below is the problem listed directly out of the book:
"you drop a ball from a window located on an upper floor of a building. It strikes the ground with speed v. You now repeat the drop, but your friend down on the ground throws another ball upward at the same speed v, releasing her ball at the same moment that you drop yours from the window. At some location, the balls pass each other. Is this location (a) at the halfway point between the window and the ground, (b) above this point, or (c) below this point.
*Our teacher later clarified that one should consider the results as if the ball leaves the ground at speed v (no acceleration, and not having taken off from 'your friend's hand' somewhere above the ground).
Since there are no hard numbers attached, the only one I can think of is a=9.8m/s^2
So, when I drew out a graph (I used standard gravitational acceleration and a four second interval), I saw that at at the halfway point in time the ball thrown from the roof was significantly above the halfway point and the one thrown from the ground was significantly above this point. Beyond that, one can reason that due to the acceleration of the ball, the 'fast half' of the journey of each ball is from this midpoint to the ground. After checking this reasoning against many of my peers, as well as my calculus teacher, they confirmed I'm right.
However, the book, as well as my physics teacher claims that this problem when graphed, forms two inverse, completely linear acceleration graphs, and therefore the balls meet at the midpoint between the ground and the roof.
This can't be, can it? I believe my reasoning is sound, but I'm just a first year physics student arguing with my AP physics teacher who is sure she is right...
Have you tried running through the calculations rather than graphing?
You know the acceleration of both balls, and you know the initial speed and position of both balls.
Quick question about you're calculus experience (since you mentioned AP). Are you just doing derivatives or are you doing integrals (~antiderivatives) as well?
Your Physics teacher is mistaken. They meet 3/4 of the way up.
At that point in time, their velocities are -1/2v and 1/2v.
Edit: If you are up for it, I recommend that you find the general case for d1(t) and d2(2) at tf, where tf (t final) is the time the ball that is dropped hits the ground. Evaluate both at tf/2, and show that d1(tf/2) = d2(tf/2). Then take the result and compare it to 1/2*d1(0).
FAQ: Quick question on a one-dimesnional motion problem
What is one-dimensional motion?
One-dimensional motion refers to the movement of an object along a single straight line. This type of motion can be described using only one coordinate, such as distance or position, and is often depicted on a graph as a straight line.
How is one-dimensional motion different from two or three-dimensional motion?
One-dimensional motion only involves movement along a single straight line, while two and three-dimensional motion involves movement in multiple directions. This means that one-dimensional motion can be described using one coordinate, whereas two and three-dimensional motion require multiple coordinates to fully describe an object's movement.
What are some common examples of one-dimensional motion?
Some common examples of one-dimensional motion include a car driving along a straight road, a ball rolling down a ramp, or a person walking in a straight line.
How is velocity calculated in one-dimensional motion?
Velocity in one-dimensional motion is calculated by dividing the change in position by the change in time. This can be represented by the equation v = Δx/Δt, where v is velocity, Δx is the change in position, and Δt is the change in time.
What are some important concepts to understand when solving one-dimensional motion problems?
Some important concepts to understand when solving one-dimensional motion problems include displacement, velocity, acceleration, and the relationship between distance, time, and speed. It is also important to understand the difference between average and instantaneous values and how to use equations of motion to solve for unknown variables.
