Quick question on experimental errors
In summary, a student is testing the kinematic equations for uniformly accelerated motion by measuring the time it takes for light-weight plastic balls to fall to the floor from a height of 3 m in the lab. The measured time is 35% greater than the predicted time using g as 9.80 m/s^2. The most likely cause of this large percent error is D) the acceleration of the plastic balls is not uniform, as air resistance reduces the acceleration and leads to a non-constant acceleration, while the non-spherical shape of the balls is only a small correction.
RoboNerd
410
A student is testing the kinematic equations for uniformly accelerated motion by measuring the time it takes for light-weight plastic balls to fall to the floor from a height of 3 m in the lab. The student predicts the time to fall using g as 9.80 m/s^2, but finds the measured time to be 35% greater. Which of the following is the most likely cause of the large percent error?
A) acceleration due to gravity is 70% greater than 9.80 m/s^2 at this location.
B) acceleration due to gravity is 70% less than 9.80 m/s^2 at this location.
C) air resistance increases the downward acceleration.
E) The plastic balls are not truly spherical.
basic kinematics and common sense
I was able to narrow it down to E and D. If a ball is not truly spherical (and has more of a plate-like shape), then I thought that would increase surface area for the drag forces that would increase flight time. However, the solutions say this the correct answer is D. Could anyone please explain to me why I am wrong and they are right?
Thanks in advance!
Well! However, non spherical "ball" it may be! It won't have a plate like shape!
I mean it will have a bulging shape... more surface area... more drag?
A non-spherical shape is a small correction to the dominant effect of (D), which should be phrased as "air resistance reduces the acceleration" (but it also leads to a non-constant acceleration).
OK thanks! That makes sense!
FAQ: Quick question on experimental errors
What are experimental errors?
Experimental errors refer to discrepancies or mistakes that occur during the process of conducting a scientific experiment. These can include human error, faulty equipment, or external factors that may affect the results.
Why is it important to identify and address experimental errors?
Identifying and addressing experimental errors is crucial in ensuring the validity and accuracy of scientific research. If errors are not accounted for, the results of an experiment may be skewed and lead to incorrect conclusions.
What are some common sources of experimental errors?
Some common sources of experimental errors include measurement errors, calculation errors, contamination, and bias. These can occur at any stage of the experiment, from the design to the data analysis.
How can experimental errors be reduced or minimized?
Experimental errors can be reduced or minimized by carefully planning and designing the experiment, using reliable equipment, following proper procedures, and repeating the experiment multiple times to check for consistency.
What should be done if experimental errors are identified?
If experimental errors are identified, they should be addressed and corrected before drawing any conclusions. This may involve repeating the experiment, adjusting procedures, or using more accurate equipment.
