Quick question on integral calculation
matts0
Hello, I have a question from my textbook on integral calculation. It's
Find f(pi/2) from the following information.
(i) f is positive and continuous.
(ii) the area under the curve y=f(x) from x=0 to x=a is a2+(a/2)*sin(a)+(π/2 )*cosa
So I think the second condition implies
F(a)-F(0) = a2+(a/2)*sin(a)+(π/2 )*cosa (F is the antiderivate of f)
But if I let a=0, I find the lefthand side of the equation will be 0 but the righthand side will be π/2 .
So please someone tell me where I made a mistake which seems to be quite a silly one.
Thanks in advance.
Did you calculate the derivative?
Either you copied the question incorrectly or else the book has written an incorrect question. You are right: the two sides are different in the limit a-->0.
RGV
There are two things I don't understand about this problem. First, when finding the nth root of a number, there should in theory be n solutions. However, the formula produces n+1 roots. Here is how. The first root is simply ##\left(r\right)^{\left(\frac{1}{n}\right)}##. Then you multiply this first root by n additional expressions given by the formula, as you go through k=0,1,...n-1. So you end up with n+1 roots, which cannot be correct. Let me illustrate what I mean. For this...
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
