Quick questions regarding BRA KET notation
In summary: That is, if we can find a set of vectors ## B=\{ | n \rangle \}_{n=1}^{\infty} ## such that for all pairs of vectors in this set, we have ## \langle k | l \rangle =\delta_{k l} ## and for all vectors ## | x \rangle ##, we can write ## |x\rangle =\sum_{n=1}^{\infty} x_n | n \rangle ## where ## x_n =\langle n | x \rangle ##, we can say that ## B ## is a basis of the Hilbert space and ## | x \rangle ## can be represented as a linear combination of basis vectors ## | x \rangle
rwooduk
762
59
I'm trying to apply BRA KET notation to my notes on particle physics.
please could someone confirm that the kroneker delta function may be written
[tex]\delta _{ij} = \left \langle i |j \right \rangle[/tex]
OR would it be written
δij = |i> <j|
I know i and j are indices, so can BRA KET even be used?
Also if you have the Levi-Civita Tensor εijk is it possible to write this in BRA KET form?
In particular take this identity:
[tex]\varepsilon _{ijk} \varepsilon _{ilm} = \delta _{jl} \delta _{km} - \delta _{jm} \delta _{kl}[/tex]
how would this be written in BRA KET, or am I mixing things up? it would be nice if at all possible to use BRA KET in my particle as I found using it very useful in last semesters quantum!
thanks for any ideas / guidance!
You're mixing things up.
In QM, states are represented by kets, which are vectors in an abstract Hilbert space(a vector space with some properties). So ## |\phi\rangle , |i \rangle , |\uparrow \rangle ,... ## are abstract vectors.
## \langle i | j \rangle ## is the inner product of vectors ## |i \rangle ## and ## |j \rangle ##. Only if they're part of an orthonormal set of vectors, you can write ## \langle i | j \rangle=\delta_{ij} ##, otherwise the inner product can be any complex number. So ## \langle i | j \rangle=\delta_{ij} ## is not a representation of Kronecker delta but only a way of saying that we have a orthonormal set of vectors.
And about ## | i \rangle \langle j | ##. This is an operator, something that gets a vector and gives another vector. But its not what Kronecker delta does its not an operator and so ## \delta_{ij}=| i \rangle \langle j | ## is wrong too!
Not only that these are not representations of Kronecker delta, but also people usually don't use such representations because ## \delta_{ij}=\left\{ \begin{array}{lr} 1 \ \ \ i=j \\ 0 \ \ \ i\neq j \end{array} \right. ## is good enough.
Likes rwooduk
Not only that it is not, in general, a representation of Kronecker delta, but also people usually don't use such representations because ## \delta_{ij}=\left\{ \begin{array}{lr} 1 \ \ \ i=j \\ 0 \ \ \ i\neq 0 \end{array} \right. ## is good enough.
And about ## | j \rangle \langle i | ##. This is an operator, something that gets a vector and gives another vector. But its not what Kronecker delta does its not an operator and so ## \delta_{ij}=| j \rangle \langle i | ## is wrong too!
hmm but couldn't you also apply ## | j \rangle \langle i | ## sort of like this:
[tex]x_{i} \delta _{ij} y_{i} = \left \langle x|\delta |y \right \rangle[/tex]
would that be correct?
aside from that, thanks for the reply, was hoping to apply BRA and KET but if it's incorrect then I'll just use standard notation.
rwooduk said:
[itex]x_i \delta_{ij}y_i=\langle x | \delta | y \rangle[/itex]
You mean ## \langle x | (| i \rangle \langle j |)| y \rangle=\langle x| i \rangle \langle j | y \rangle=\langle i| x \rangle^* \langle j | y \rangle=x_i^* y_j##?
This is correct only if ## | i \rangle ## and ##| j \rangle## are part of an orthonormal set of vectors. But this has nothing to do with Kronecker delta. Because ## \delta_{ij}=\left\{ \begin{array}{lr} 1 \ \ \ i=j \\ 0 \ \ \ i\neq j \end{array} \right. ## is a number: 0 or 1. Its just a compact way of writing particular conditionals to choose between 0 and 1 but it still means a number! But ## | i \rangle \langle j | ## is an operator.
Likes rwooduk
Yes, that's what I meant, hmm indeed, yes i and j are just numbers not part of an orthonormal set of vectors, ok guess I better start getting used to the upcoming new notation! Thanks very much you have saved me from making errors and a large amount of time!
It seems you misunderstood things. i and j are numbers but ## |i\rangle ## and ## |j\rangle ## are vectors. Now if we can find a set of vectors ## B=\{ | n \rangle \}_{n=1}^\infty ## such that for all pairs of vectors in this set, we have ## \langle k | l \rangle =\delta_{k l} ## and ## |i\rangle \in B ## and ## |j\rangle \in B ## , we can say ## |i\rangle ## and ## |j\rangle ## are part of an orthonormal set of vectors, otherwise they're just vectors.
If conditions above are satisfied, then any other vector ##|x\rangle ## can be written as a linear combination of members of B, i.e. ## |x\rangle=\sum_{n=1}^\infty x_n |n\rangle ## where ## x_n ## are complex numbers. Then we can write ## \langle i |x\rangle=\sum_{n=1}^\infty x_n \langle i|n\rangle=\sum_{n=1}^\infty x_n \delta_{in}=x_i ##.
Likes rwooduk
thanks, yes i misunderstood, that's much clearer! thanks again.
FAQ: Quick questions regarding BRA KET notation
What is BRA KET notation?
BRA KET notation is a mathematical notation used in quantum mechanics to represent the state of a quantum system. It consists of two symbols, the bra ⟨ and the ket ⟩, which are used to enclose vectors representing the state of the system.
Why is BRA KET notation used in quantum mechanics?
BRA KET notation is used in quantum mechanics because it provides a concise and elegant way of representing the state of a quantum system. It also allows for easy manipulation and calculation of quantum states and operators.
How do I read BRA KET notation?
To read BRA KET notation, you can think of the bra symbol ⟨ as "bra vector" and the ket symbol ⟩ as "ket vector". The vector inside the bra or ket represents the state of the system, and the two symbols together indicate an inner product between two vectors.
What is the difference between a bra and a ket in BRA KET notation?
The main difference between a bra and a ket in BRA KET notation is their orientation. A bra vector is written as a row vector, while a ket vector is written as a column vector. This distinction is important in calculations involving bra and ket vectors.
Can BRA KET notation be used in other fields of science?
BRA KET notation was originally developed for use in quantum mechanics, but it has also been applied in other fields such as quantum information theory and linear algebra. However, its use may be limited in other areas of science that do not involve quantum systems.
