How to Find Particle Speed in Different Reference Frames Using Relativity?
In summary, the question asks for the speed of a particle moving at 0.9c in frame S'' relative to frames S' and S. It is a typo to ask for the speed relative to S'' as it is already given. The relativistic velocity transform formula can be used to find the speed relative to S' and S, and it is helpful to work with covariant quantities and rapidities.
MostlyHarmless
345
(Verbatim) A particle moves with speed .9c along the x'' axis of frame S'', which moves with speed .9c in the positive x'-direction relative to frame S'. Frame S' moves with speed .9c, in the positive x-direction, relative to S. a.) Find the speed of the particle relative to S', and b.) S''.
Relativistic Velocity Transform: $$u'_x= \frac{u_x-v}{1-\frac{vu_x}{c^2}}$$
My question is more or less just about the interpretation of the question.
The first line, does that mean, the particle's rest frame is S''? Or that the particle is at rest in S'' which is moving at .9c?
It means that the particle is moving in S, S' is moving with respect to S, and S'' is moving with respect to S'. Otherwise there is no point in asking for the speed in S''.
No, the question tells you that the particle is moving with 0.9c in reference frame S" and S" is moving with respect to S' with a velocity of 0.9c which in turn moves with speed 0.9c wrt. S. It's not said that any of these systems is the restframe of the particle. Just calculate!
Hint: It's easier to work with covariant quantities. Since all boosts are in the same direction, it's useful to work with rapidities!
If the particle is moving at the given speed wrt S'', why does the question ask for the particle's speed wrt S''?
That's a typo. They want you calculate the speeds relative to S' and S - not S' and S''. The speed relative to S'' is given.
FAQ: How to Find Particle Speed in Different Reference Frames Using Relativity?
1. What is a quick relativity problem set up?
A quick relativity problem set up is a scientific exercise or task that involves applying the principles of relativity to a given scenario or situation. It is typically used as a tool for understanding and practicing the concepts of relativity, such as time dilation and length contraction.
2. How is a quick relativity problem set up useful for scientists?
A quick relativity problem set up allows scientists to test and apply their knowledge of relativity in a controlled and practical manner. It also helps to develop critical thinking and problem-solving skills that are crucial in the field of science.
3. Can anyone attempt a quick relativity problem set up?
Yes, anyone with a basic understanding of the principles of relativity can attempt a quick relativity problem set up. However, it is recommended to have a strong foundation in physics and mathematics to fully grasp the concepts involved.
4. Are there different types of quick relativity problem set ups?
Yes, there are various types of quick relativity problem set ups, each with its own unique scenario and set of variables. Some examples include spaceship travel, twin paradox, and time dilation in accelerated frames.
5. What are the benefits of practicing quick relativity problem set ups?
Practicing quick relativity problem set ups can improve one's understanding and application of relativity concepts, which can be useful in various fields of science such as astrophysics and quantum mechanics. It also helps to develop critical thinking skills and problem-solving abilities.
