Quick Surface Area and Application Question
In summary, when using the SA formula for cardiac output, it is important to use the Simpson's Rule in the denominator with delta x = 2.
ardentmed
158
For the first one, I'm completely dumbfounded. I used the SA formula for and ended up getting 2 $π\int_{π/6}^{0} \, cos2x * √1+4sin(2x)^2 ) $
And took u = sin2x, ultimately giving me $ π\int_{√3/2}^{0} \,d (1+ 4u^2)^(1/2) $
I'm lost as to what to do next. I'm almost definite that my u-substitution is incorrect.
Also for the second one, I used the formula for cardiac output, which is mg/ $\int_{b}^{a} \,d $ , which gave me 78.533 by using the Simpson's Rule in the denominator with delta x = 2.
Any ideas?
Thanks in advance.
Any ideas?
Thanks in advance.
For the first one:
The formula is the following:
$$S= \int 2 \pi y ds , \ \text{ where } ds=\sqrt{1+(\frac{dy}{dx})^2}dx$$
$\displaystyle{\frac{dy}{dx}=\frac{\cos{(2x)}}{dx}=-2\sin{(2x)} }$
$\displaystyle{\sqrt{1+(\frac{dy}{dx})^2}=\sqrt{1+(-2\sin{(2x)} )^2}=\sqrt{1+4\sin^2{(2x)}}}$
So $$S=\int_0^{\frac{\pi}{6}} 2 \pi y \sqrt{1+4\sin^2{(2x)}}dx=\int_0^{\frac{\pi}{6}} 2 \pi \cos{(2x)} \sqrt{1+4\sin^2{(2x)}}dx$$
Set $u=\sin{(2x)}$, then:
when $x=0 \Rightarrow u=0$
when $x=\frac{\pi}{6} \Rightarrow u=\frac{\sqrt{3}}{2}$
$du=2 \cos{(2x)}dx$
$$S=\int_0^{\frac{\pi}{6}} 2 \pi \cos{(2x)} \sqrt{1+4\sin^2{(2x)}}dx=\int_0^{\frac{\sqrt{3}}{2}} \pi \sqrt{1+4u^2}du=\int_0^{\frac{\sqrt{3}}{2}} \pi \sqrt{1+(2u)^2}du$$
Set $2u=\tan{w}$, then:
when $u=0 \Rightarrow w=0$
when $u=\frac{\sqrt{3}}{2} \Rightarrow \tan{w}=\sqrt{3} \Rightarrow w=\frac{\pi}{3}$
$2du=\frac{1}{\cos^2{w}}dw$
$$S=\int_0^{\frac{\sqrt{3}}{2}} \pi \sqrt{1+(2u)^2}du=\int_0^{\frac{\pi}{3}} \frac{\pi}{2} \sqrt{1+\tan^2{w}}\frac{1}{\cos^2{w}}dw=\int_0^{\frac{\pi}{3}} \frac{\pi}{2} \sqrt{\frac{1}{\cos^2{w}}}\frac{1}{ \cos^2{w}}dw=\int_0^{ \frac{ \pi}{3}} \frac{\pi}{2} \frac{1}{ \cos^3{w}}dw=\frac{\pi}{2} \int_0^{ \frac{ \pi}{3}} \frac{\cos{w}}{ \cos^4{w}}dw=\frac{\pi}{2} \int_0^{ \frac{ \pi}{3}} \frac{\cos{w}}{ (1-\sin^2{w})^2}dw$$
Set $v=\sin{w}$, then:
when $w=0 \Rightarrow v=0$
when $w=\frac{\pi}{3} \Rightarrow v=\frac{\sqrt{3}}{2}$
$dv=\cos{w}dw$
$$S=\frac{\pi}{2} \int_0^{ \frac{ \pi}{3}} \frac{\cos{w}}{ (1-\sin^2{w})^2}dw=\frac{\pi}{2} \int_0^{ \frac{\sqrt{3}}{2}} \frac{1}{ (1-v^2)^2}dv=\frac{\pi}{2} \int_0^{ \frac{\sqrt{3}}{2}} \frac{1}{ (v^2-1)^2}dv= \\ \frac{\pi}{2} \int_0^{ \frac{\sqrt{3}}{2}} (\frac{A}{ (v-1)}+\frac{B}{v+1})^2dv$$
Calculate the values of $A$ and $B$ as followed:
$\displaystyle{\frac{A}{ v-1}+\frac{B}{v+1}=\frac{1}{(v-1)(v+1)}}$
Can you continue from here?
Excellent. Thank you for your insightful response.
Does anyone know the solution to the second question? I used the formula for cardiac output, which is mg/ ∫abd , which gave me 78.533 by using the Simpson's Rule in the denominator with delta x = 2.
Thanks.
FAQ: Quick Surface Area and Application Question
What is surface area and why is it important in science?
Surface area is the measure of the total area that the surface of an object occupies. It is important in science because it helps us understand the properties and behavior of substances, such as how they interact with other materials and their ability to absorb or release heat and energy.
How do you calculate surface area?
The specific calculation for surface area depends on the shape of the object. For example, the surface area of a cube can be calculated by multiplying the length of one side by itself, and then multiplying that result by six (since there are six sides on a cube). Other shapes have their own formulas for calculating surface area.
How is surface area used in real life applications?
Surface area is used in a wide range of real life applications, including determining the amount of paint or wrapping paper needed for an object, calculating the dosage of medicine based on the surface area of the patient's body, and designing more efficient solar panels by maximizing their surface area for sunlight absorption.
How does surface area affect the rate of chemical reactions?
The surface area of a substance can greatly affect the rate of a chemical reaction. This is because a larger surface area means there is more area available for the reactants to come into contact with each other, leading to a faster reaction. This is why substances are often broken down into smaller particles to increase their surface area and speed up reactions.
Can surface area be changed or manipulated?
Yes, surface area can be changed or manipulated in various ways. For example, cutting an object into smaller pieces or changing its shape can increase its surface area. Additionally, chemical reactions can also change the surface area of a substance, such as when a solid dissolves in a liquid, increasing its surface area for the reaction to occur.
