MHB Quickest way to calculate argument of a complex number
The quickest way to calculate the argument of the complex number πe^{-3iπ/2} is to recognize that its argument can be expressed as -3π/2 + 2kπ, where k is an integer. For the principal value, k should be chosen to keep the result within the range of (-π, π] or [0, 2π), depending on the definition used. In this case, selecting k = 1 yields the principal value of the argument as π/2. The magnitude of the complex number is confirmed to be π. This method efficiently determines the argument while adhering to the principal value constraints.
Guest2
What's the quickest way to calculate the argument of $\displaystyle \pi e^{-\frac{3i\pi}{2}}$?
Mathematics news on Phys.org
To be sure, I know that $|\displaystyle \pi e^{-\frac{3i\pi}{2}}| = \pi.$
The argument of $\displaystyle \pi e^{-\frac{3i\pi}{2}}$ can take any value of the form $-\dfrac{3\pi}2 + 2k\pi$, where $k$ is an integer. If you want the principal value of the argument then you need to choose $k$ so as to get a value in the range $(-\pi,\pi]$ (or maybe $[0,2\pi)$, depending on which definition you are using for the principal range). In this example, you would want $k = 1$, giving the principal value of the argument as $\dfrac\pi2.$
Opalg said:
Thank you very much! :D
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
