Quickly Calculate $\text i^{n}$ Values
  • MHB
  • Thread starter Drain Brain
In summary, To quickly determine the values of different powers of $\text i$, you only need to remember that $i^0 = 1$, $i^1 = i$, $i^2 = -1$, $i^3 = -i$, and $i^4 = 1$. Multiplying or dividing by $i^4$ does not change the result, and the only thing that matters is the remainder of the exponent when divided by $4$. The powers of $i$ form a 4-cycle and multiplying by $i$ can be thought of as rotating counter-clockwise by a quarter-turn. This explains the rule that negative times negative equals positive. Therefore, $i^{587} = -i$.
Drain Brain
144
can you teach me how to quickly determine the values of the different powers of $\text i$ e.g $\text i^{587}$?
regards!
Mathematics news on Phys.org
You only need to remember that $i^0 = 1$, $i^1 = i$, $i^2 = -1$, $i^3 = -i$ (you really only need $i^2 = -1$, everything else is easily derivable) and that $i^4 = (i^2)^2 = (-1)^2 = 1$. That last relation means that if you are given a power of $i$, you can multiply or divide it by $i^4$, which does not change the result since $i^4$ is just one, but let's you add or subtract $4$ to/from the exponent. That means adding or subtracting 4 to the exponent makes no difference:
$$i^3 = i^7 = i^{11} = \cdots$$
$$i^3 = i^{-1} = i^{-5} = \cdots$$
Therefore the only thing that matters is the remainder of the exponent when divided by $4$:
$$i^k = \begin{cases} 1 ~ ~ \text{if} ~ k ~ \text{leaves a remainder of 0 when divided by} ~ 4 \\ i ~ ~ \text{if} ~ k ~ \text{leaves a remainder of 1 when divided by} ~ 4 \\ -1 ~ ~ \text{if} ~ k ~ \text{leaves a remainder of 2 when divided by} ~ 4 \\ -i ~ ~ \text{if} ~ k ~ \text{leaves a remainder of 3 when divided by} ~ 4 \end{cases}$$​
The powers of $i$ form what professional mathematicians call a 4-cycle, which means exactly what you think it means. So:
$i^0 = 1$ (this is sort of "by default")
$i^1 = i$
$i^2 = -1$
$i^3 = (i^2)i = (-1)i = -i$
$i^4 = (i^2)(i^2) = (-1)(-1) = 1$, and we have come "full cycle" and it just repeats forever more after this.
Multiplying by $i$ can be thought of as "rotating counter-clockwise by a quarter-turn" (this should make sense, since we repeat every 4 1/4-turns), and thus multiplying by -1 can be thought of as an "about face" (a "180" as skaters like to call it), which perhaps (finally!) explains the curious rule that:
negative*negative = positive.
Therefore:
$i^{587} = i^{4\ast146 + 3} = (i^{4\ast146})(i^3) = (i^4)^{146}(i^3) = (1^{146})(i^3) = (1)(i^3) = i^3 = -i$
FAQ: Quickly Calculate $\text i^{n}$ Values
What is the formula for calculating $\text i^{n}$ values?
The formula for calculating $\text i^{n}$ values is $i^{n} = i^{n-4k}$ where k is the remainder when n is divided by 4.
What are the properties of $\text i^{n}$ values?
The properties of $\text i^{n}$ values include:
1. $i^{0} = 1$
2. $i^{1} = i$
3. $i^{2} = -1$
4. $i^{3} = -i$
5. The pattern repeats every 4 exponents.
How do I use $\text i^{n}$ values to simplify complex numbers?
To simplify complex numbers using $\text i^{n}$ values, you can use the following rules:
1. $i^{2} = -1$
2. $i^{3} = -i$
3. $i^{4} = 1$
4. Use these rules to replace $i^{2}$ with -1, $i^{3}$ with -i, and $i^{4}$ with 1.
5. Simplify the remaining real and imaginary numbers.
What are some real-life applications of $\text i^{n}$ values?
Some real-life applications of $\text i^{n}$ values include:
1. Electrical engineering, to represent imaginary components in AC circuits.
2. Physics, to solve problems involving complex numbers in quantum mechanics.
3. Computer graphics and animation, to represent and manipulate 3D objects.
4. Signal processing, to analyze and process signals in both time and frequency domains.
5. Cryptography, to encrypt and decrypt information using complex numbers.
How can I calculate large $\text i^{n}$ values quickly?
To calculate large $\text i^{n}$ values quickly, you can use the following methods:
1. Use the properties of $\text i^{n}$ values to simplify the exponent.
2. Break down the exponent into smaller parts and calculate each part separately.
3. Use a calculator or computer program that has a built-in function for calculating complex numbers.
