MHB Quotient rings and homorphic images
The discussion revolves around proving that the function ϕ from F(R) to R×R is a homomorphism and onto. To demonstrate that ϕ is onto, one must find a function f in F(R) such that f(0) equals a and f(1) equals b for any given (a, b) in R×R. The suggested function is f(x) = (b-a)x + a, but clarity on the nature of F(R) is needed for further assistance. Additionally, the kernel of ϕ consists of all functions f in F(R) where f(0) and f(1) both equal zero. The conversation emphasizes the importance of defining terms clearly to facilitate understanding and support.
simo1
am given that ϕ is a function from F(R) tp RxR defined by ϕ(f)=(f(0),f(1))
i proved that ϕ is a homomorphism from F(R) onto RxR.
i showed that
1) ϕ(f) +ϕ(g)=ϕ(f+g) [for all f,g in F(R)]
2)
ϕ(f)*ϕ(g)= ϕ(f*g)
how do i show that ϕ is onto and define the kernal??(Wasntme)
Re: quotient rings and homorphic images
To show that $\phi$ is onto, given $(a,b) \in \Bbb R \times \Bbb R$ you have to exhibit one (there may be more than one) $f \in F(\Bbb R)$ with $f(0) = a, f(1) = b$.
You haven't said what kind of function-space $F(\Bbb R)$ is: in fact, I am only guessing that by R you mean the real numbers.
I suspect that the function $f(x) = (b-a)x + a$ will do the trick, but in order for us to help you, we need YOU to define your terms. We all aren't using YOUR textbook, or lecture notes.
The kernel of $\phi$ is all $f \in F(\Bbb R)$ such that $f(0) = f(1) = 0$. That's about as specific as I can get without more information.
yes by R it is real numbers. and everythin that I wrote is as it is on the texbook. are there options here on mathshelpboard that we can use to show real numbers, complex etc
If you use the buttons, there is a button labeled $\Sigma$ that creates $$ tags that wrap around your text.
This let's you type expressions in Latex, which makes "pretty math symbols". For example putting:
\sqrt{x^2 + 1}
inside the tags produces:
$$\sqrt{x^2 + 1}$$
You can also enter Latex directly, by using the dollar sign as a delimiter (for in-line latex) or a double dollar sign (which produces "centered display style").
The Latex code for the "blackboard bold" font that is used for the sets you listed is either:
\mathbb{text goes here}
or the code \Bbb, for example:
\Bbb Z
inside [math] tags or dollar signs produces:
$\Bbb Z$
You still haven't told us what is meant by $F(\Bbb R)$, although I guess it is a set of functions $f:\Bbb R \to \Bbb R$. Knowing which functions would be nice.
I am studying the mathematical formalism behind non-commutative geometry approach to quantum gravity. I was reading about Hopf algebras and their Drinfeld twist with a specific example of the Moyal-Weyl twist defined as F=exp(-iλ/2θ^(μν)∂_μ⊗∂_ν) where λ is a constant parametar and θ antisymmetric constant tensor. {∂_μ} is the basis of the tangent vector space over the underlying spacetime Now, from my understanding the enveloping algebra which appears in the definition of the Hopf algebra...
