Quotient set of an equivalence relation
In summary: Similarly, [k+ 2]= [2], [k+ 3]= [3],..., [2k- 1]= [k-1], [2k]= [0]. Notice that [1], [2],... [k-1] are not only distinct equivalence classes, they are exactly the same as [k+1], [k+ 2],..., [2k]. That is, there are actually only k equivalence classes, not 2k. So the "quotient set" is Z/\triangleright= {[0], [1], [2],... [k-1]}.
Luna=Luna
On the set of Z of integers define a relation by writing m [itex]\triangleright[/itex] n for m, n [itex]\in[/itex] Z.
m[itex]\triangleright[/itex]n if m-n is divisble by k, where k is a fixed integer.
Show that the quotient set under this equivalence relation is:
Z/[itex]\triangleright[/itex] = {[0], [1], ... [k-1]}
I'm a bit new the subject of Set Theory so I'm a bit unsure as to how to go about solving this.
If m-n is divisble by k, where k is a fixed integer then show that the quotient set under this equivalence relation is:
[itex]\triangleright[/itex] seems to be undefined. You say it is a relationship without saying what it is.
sorry it wasn't clear from my post, I've rewritten the post to be a bit more clear.
The relationship is:
m[itex]\triangleright[/itex]n, if m-n is divisble by k, where k is a fixed integer.
But you also haven't said what "[1]", "[2]", ... "[k]" are. Of course, they are the equivalence classes but unless your question is "why are there k classes" rather than "why are the classes what they are", you need to specify "what they are"! Essentially what you wrote was that you want to prove that the "quotient set" is the "set of equivalence classes" which is basically the definition of "quotient set"!
(Similar to writing "Luna= Luna"!)
Start with k= 1. All numbers in the same equivalence class with it ([1]) are numbers n such that n- 1 is divisible by k. That is the same as saying "n- 1= mk" for some m or n= mk+ 1. That is, all numbers that are 1 more than a multiple of k: [1]= {..., -2k+ 1, -k+ 1, 1, k+ 1, 2k+ 1, ...}. Similarly, [2]= {..., -2k+ 2, -k+ 2, 2, k+ 2, 2k+ 2, ...}. You can do that until you get to [k]= {..., -2k, -k, 0, k, 2k, ...} which is the same as [0]. If we try to do the same thing with k+ 1, we get [k+1]= {..., -2k+ (k+1), -k+ (k+1), k+ 1, k+ (k+ 1), 2k+ (k+ 1), ...}= {..., -k+ 1, 1, k+ 1, 2k+ 1, 3k+ 1, ...} which is exactly the same as [1].
Likes 1 person
However, from my understanding, a quotient set is a set that contains all possible equivalence classes of a given equivalence relation. In this case, the relation \triangleright is defined as m\trianglerightn if m-n is divisible by k. This means that for any two integers m and n, if their difference is divisible by k, then they are in the same equivalence class.
To find the quotient set, we need to determine all the possible equivalence classes. Let's start with the equivalence class [0]. This means that for any integer m, m-0 must be divisible by k. This is only possible if k divides m, so the equivalence class [0] contains all integers that are divisible by k.
Next, let's consider the equivalence class [1]. This means that for any integer m, m-1 must be divisible by k. In other words, m must be 1 more than a multiple of k. So, the equivalence class [1] contains all integers that are 1 more than a multiple of k.
Following this pattern, we can see that each equivalence class will contain integers that are a certain number more than a multiple of k, where that number ranges from 0 to k-1. Therefore, the quotient set under this equivalence relation will be {[0], [1], ..., [k-1]}.
In summary, the quotient set of the given equivalence relation on the set of integers Z is a set containing all possible equivalence classes, which are determined by the remainder when dividing by k. This can be represented as {[0], [1], ..., [k-1]}.
Related to Quotient set of an equivalence relation
1. What is the quotient set of an equivalence relation?
The quotient set of an equivalence relation is a set of all the equivalence classes formed by the relation. It represents the partitioning of the original set into subsets that are equivalent to each other.
2. How is the quotient set different from the original set?
The quotient set is different from the original set because it is a set of subsets, while the original set is a collection of individual elements. The elements in the quotient set are not distinct, but rather grouped together based on their equivalence relation.
3. How is the quotient set related to the concept of equality?
The quotient set is related to the concept of equality because it groups together elements that are considered equal under the equivalence relation. This means that any two elements in the same equivalence class are equivalent or "equal" to each other.
4. Can the quotient set be empty?
Yes, the quotient set can be empty if the equivalence relation does not have any elements in common. This means that there are no subsets or equivalence classes formed, and the quotient set will be empty.
5. How is the quotient set used in mathematics?
The quotient set is used in mathematics to simplify problems involving equivalence relations. It helps to reduce the number of elements that need to be considered by grouping them into equivalence classes, making it easier to analyze and solve problems.
  • Topology and Analysis
