MHB R-modules and Homomorphism of Rings
  • Thread starter Thread starter Sudharaka
    Rings
Sudharaka
MHB
Hi everyone, :)
I find it difficult to get the exact meaning of the following question. What does "in a natural way" means? Is it that we have to show that there exist a isomorphism between \(S\) and a sub-module of \(R\)? Any ideas are greatly appreciated. :)
Question:
Given a ring homomorphism \(f:R\rightarrow S\), show that every \(S\)-module can be considered as an \(R\)-module in a natural way.
Sudharaka said:
Hi everyone, :)
Question:
I think I am getting some understanding. Suppose if we have a \(S\)-module called \(M\). Then we can define the operation \(R\times M\rightarrow M\) as, \(r.m=f( r)\,m\). Under this operation it's clear that \(M\) becomes a \(R\)-module. This can be verified by showing that \(M\) satisfies the \(R\)-module properties under the operation defined above.
This I believe is the natural way of defining an \(R\)-module from a given \(S\)-module where \(R\) and \(S\) are homomorphic. Correct me if I am wrong. :)
Yes.
It is "natural" because it's pretty much the only way you have available to define
$r.m$.
This theorem tells us, for example, that any $\Bbb Z_n$-module can simply be regarded as a $\Bbb Z$-module, that is: an abelian group, and explains why reducing a polynomial (mod p) can be so useful in investigating polynomials with integer coefficients, because often information in the $S$-module can be "lifted" to an $R$-module.
Deveno said:
Yes.
$r.m$.
Thank you so much. I am sure your immense knowledge about these things will be of great help to me this semester. :)
Thread 'Derivation of equations of stress tensor transformation'
Hello ! I derived equations of stress tensor 2D transformation. Some details: I have plane ABCD in two cases (see top on the pic) and I know tensor components for case 1 only. Only plane ABCD rotate in two cases (top of the picture) but not coordinate system. Coordinate system rotates only on the bottom of picture. I want to obtain expression that connects tensor for case 1 and tensor for case 2. My attempt: Are these equations correct? Is there more easier expression for stress tensor...
