R parity conserving susy models
In summary, R parity is a theoretical concept that is not a fundamental law of nature, and its conservation or violation can vary in different SUSY models. Thank you.
Amith2006
427
Hi,
I was going through the concept of R parity in SUSY. In the case of SUSY we do not have Baryon and Lepton number conservation instead we have R parity conservation defined by,
R-parity= (-1)^2s+3B+L
which is required for the proton to be stable. But it has been found that this condition need not be satisfied for proton stability. Instead we can have either Lepton number or Baryon number conserving terms in the Lagrangian which serves the purpose. My question is- 'There are so many SUSY models and so can we have any model to be R parity conserving or violating by the same recipe'? Thanks.
Hello,
Thank you for bringing up the concept of R parity in SUSY. R parity conservation is indeed an important aspect of supersymmetry and plays a crucial role in the stability of the proton. However, as you mentioned, it is not the only way to ensure proton stability.
There are indeed many SUSY models and each one of them may have different R parity conservation or violation properties. This is because R parity is a theoretical concept and not a fundamental symmetry of nature. It is a useful tool for organizing the particles in a SUSY theory and for understanding their interactions, but it is not a requirement for the theory to work.
In fact, there are some models where R parity is explicitly violated, and yet the theory remains consistent and can explain observed phenomena. This is because R parity is not a fundamental law of nature, but rather a constraint that we impose on our theoretical models.
Therefore, it is possible to have SUSY models that are R parity conserving or violating, depending on the specific model and its parameters. It is also possible to have models that have a mix of R parity conserving and violating terms, as long as they still satisfy the conditions for proton stability.
I hope this helps to clarify your question. Thank you for your interest in supersymmetry and its implications for particle physics.
Related to R parity conserving susy models
1. What is R parity in SUSY models?
R parity is a quantum number that is used to distinguish between particles and their superpartners in supersymmetric (SUSY) models. It is defined as (-1)^3B+L+S, where B is baryon number, L is lepton number, and S is spin. This means that particles have R parity of +1, while their superpartners have R parity of -1.
2. Why is R parity important in SUSY models?
R parity conservation is necessary in SUSY models to prevent the rapid decay of the lightest supersymmetric particle (LSP). This LSP is a candidate for dark matter and is required to be stable in order to explain the observed amount of dark matter in the universe.
3. How does R parity conservation affect collider experiments?
R parity conservation leads to the production of pairs of superpartners at collider experiments, as the total R parity of the initial particles must be conserved. This can result in missing energy signatures, as the LSP is undetectable and escapes the detector.
4. Are there any exceptions to R parity conservation in SUSY models?
While R parity conservation is a common assumption in SUSY models, there are some models that allow for violation of R parity. This can lead to new decay channels for the superpartners and affect collider experiments as well as dark matter searches.
5. What experimental evidence supports R parity conservation in SUSY models?
While there is no direct evidence for R parity conservation, it is a necessary assumption in order to explain the observed amount of dark matter in the universe. Additionally, collider experiments have not yet observed any violation of R parity, providing indirect support for its conservation.
