R= the square root of x^2 + y^2
In summary, the problem involves finding the x, y, and z components of a displacement vector from base camp to the summit of a mountain, as well as its length. The angle between the z and x axis is given as 32.4 degrees and the hypotenuse of the triangle formed between these two is 4580 meters. Using trigonometric functions, the x and z displacements can be calculated as -1484.73 meters and 2362.16 meters respectively. The length of the displacement vector can be found using the Pythagorean theorem, which gives a value of 2777.52 meters.
CarlosNunes
This problem is #17 in Chapter 3 of Giancoli's 5th Edition Physics.
The summit of a mountain, 2085 m above base camp, is measured on a map to be 4580 m horizontally from the camp in a direction 32.4 degrees west of north, What are the x, y, and z components of the displacement vector from camp to summit? What is the length? Choose the x-axis east, y-axis north, and z axis up.
The angle refers to that between the z and x axis. The hypotenuse of the triangle made between these two is 4580. You then have the means of calculating the x and z displacements. Sin(32.4) X 4580 is the x displacement. Cos(32.4) X 4580 is the z displacement. Don't forget to make the x vector negative as you are traveling west, and positive is east. Intro physics is all about triangles and separating a magnitude (hypotenuse) into its vector components.
To solve this problem, we first need to understand the given information. The problem is asking for the displacement vector from the base camp to the summit of a mountain. The displacement vector is a vector that represents the change in position from one point to another. In this case, the x and y components of the displacement vector represent the horizontal distance from the base camp to the summit, while the z component represents the vertical distance.
To find the x and y components, we can use trigonometry. We know that the horizontal distance from the base camp to the summit is 4580 m, and the angle between the direction of the summit and the north direction is 32.4 degrees. Using the sine and cosine functions, we can determine that the x component is 4580*cos(32.4) = 3854.9 m and the y component is 4580*sin(32.4) = 2436.6 m.
To find the z component, we can use the given information that the summit is 2085 m above the base camp. Therefore, the z component is simply 2085 m.
To find the length of the displacement vector, we can use the Pythagorean theorem. The length of the displacement vector, R, is equal to the square root of the sum of the squares of its components. In this case, R = √(3854.9^2 + 2436.6^2 + 2085^2) = 5556.9 m.
In conclusion, the x, y, and z components of the displacement vector from the base camp to the summit are 3854.9 m, 2436.6 m, and 2085 m, respectively. The length of the displacement vector is 5556.9 m.
Related to R= the square root of x^2 + y^2
1. What does the expression "R= the square root of x^2 + y^2" mean?
The expression "R= the square root of x^2 + y^2" represents the formula for calculating the distance between a point (x, y) and the origin (0, 0) on a Cartesian coordinate plane.
2. How is the distance between a point and the origin calculated using this formula?
The distance between a point (x, y) and the origin (0, 0) is calculated by taking the square root of the sum of the squares of the x and y coordinates, as shown in the formula R= the square root of x^2 + y^2.
3. Can this formula be used for any point on a Cartesian coordinate plane?
Yes, this formula can be used to calculate the distance between any point and the origin on a Cartesian coordinate plane. It is a general formula that applies to all points, regardless of their location.
4. How does this formula relate to the Pythagorean Theorem?
The formula R= the square root of x^2 + y^2 is derived from the Pythagorean Theorem, which states that in a right triangle, the square of the length of the hypotenuse (the side opposite the right angle) is equal to the sum of the squares of the other two sides. This theorem can be applied to a Cartesian coordinate plane, where the distance between two points is the hypotenuse of a right triangle with sides x and y.
5. Are there any limitations to using this formula?
Yes, this formula is only applicable for calculating the distance between a point and the origin on a Cartesian coordinate plane. It cannot be used for finding the distance between two arbitrary points on the plane.
