Race with Sticks - How to select the best one?
  • Thread starter czytron
  • Tags
    Race
In summary: If you throw it perpendicular to the flow and let it fall straight down, the water will catch it at the bottom and lift it up.
czytron
Hi!
How shall I correctly describe the velocity, as function of time, for an object put in a stream of e.g. water?
My friend wanted to challenge me in the game where a stick is thrown in the water and the winner is that who's stick first reaches a certain point. Ofcourse I picked a stick with low mass and large area to make the acceleration high, but how do I describe the situation physically?
Constant acceleration is no correct assumption since the force from the water, affecting the stick, will be smaller and smaller since it's relative velocity to the water decreases, while the mass remains the same.
What physical and mathematical approach is correct here to solve this problem?
/Happy for replies
Playing "Pooh sticks"? Any stick will move at the speed of the water it is floating in. As long as the stick does float, either area nor mass is relevant.
A light weight stick will tend to float high in the water. This will expose it more to the wind and less to the water. A large stick may extend deeper in the water.
It seems clear that on a calm day in a deep stream, a stick with just barely positive buoyancy (so that it does not catch the wind) and good depth (so that it reaches water at depth that has not been slowed down by the air) would make better speed.
From experience boating, it also seems clear that picking the right launch point is far more critical than picking the right stick.
But the thrust of your problem seemed to be asking for an equation. The simplest equation would be one where the net force on the stick is directly proportional to its speed relative to the water. This leads to a differential equation of the form. dv/dt = -kv. This is one of the simplest types of differential equations there is (first order homogeneous linear). Its solution will be v = f(t) = [some multiple of] e-kt.
The k will depend on the viscosity of water and the mass and shape of your stick. The multiple will be the one that makes your starting velocity come out right.
Thanx!
Yes ofcourse every stick's terminal velocity will be that of the water, so the thing I'm interested of is the way to terminal vel.,
The type of DE seems to make sense, just I was not really sure about the proportionality assumptions.
Drag is proportional to velocity squared..
http://en.wikipedia.org/wiki/Drag_equation
The equation also contains the "reference area" which is typically the cross section presented to the flow... suggesting it's best to drop your stick at right angles to the flow.
You can throw some floating particles (grass seeds) onto the water to see where it flows faster.
It also depends on how you drop the stick. If you hold it parallel to the flow and tilt it forward, it will convert some of the kinetic energy from the fall into forward motion during the dive. It might even temporally outrun the water.
FAQ: Race with Sticks - How to select the best one?
1. What factors should I consider when selecting a race stick?
When selecting a race stick, you should consider the material, weight, length, grip, and flexibility. These factors will affect the overall performance and comfort of the stick.
2. What is the best material for a race stick?
The best material for a race stick depends on personal preference and the type of race. Carbon fiber is lightweight and provides excellent stiffness, while aluminum is more affordable and durable. Some sticks also combine these materials for a balance of weight and durability.
3. How do I determine the appropriate length for a race stick?
The length of a race stick should be determined based on your height, arm length, and the type of race. As a general rule, the stick should reach just below your chin when standing upright. However, for shorter races, a shorter stick may offer better maneuverability.
4. What type of grip is best for a race stick?
The grip of a race stick should provide comfort and control. Some sticks have a rubber grip, while others have a textured or padded grip. It is best to try out different types of grips to find the one that feels most comfortable and provides the best control for you.
5. How much flexibility should a race stick have?
The flexibility of a race stick can vary depending on personal preference and the type of race. Generally, a stiffer stick will provide more power and speed, while a more flexible stick can offer better control and maneuverability. It is important to find a balance that works for your individual needs.
