Can Radar Technology See Through Walls and Accurately Detect 3D Shapes?
In summary: Radar can detect objects 50 feet away but accuracy decreases the further away the target object is. With several receivers and a correlator, you can make a 3D image of the people moving in the next room, through the wall. They do not know you are watching, and the wifi still works. Augmented reality does not use radar, but VR objects can be given GPS locations, and can be rendered in a variety of 3D shapes.
LightningInAJar
220
30
TL;DR Summary
Using technology to detect 3D space.
I was wondering if radar is safe, can it detect near objects (lets say 50 feet away) and does it accurately see 3D shapes? I am looking for a technology that could maybe supplement augmented reality in the sense that VR objects can be given GPS locations, but don't know if there is something in front or behind it in real life and therefore always appears in foreground. Any ideas?
RADAR is more advanced than you may think. Your wifi signals are reflected by people in the next room. With several receivers and a correlator, you can make a 3D image of the people moving in the next room, through the wall. They do not know you are watching, and the wifi still works.
@LightningInAJar Well it depends on what application you want to use it for.
Radiowaves have longer wavelengths than visible light for example so if you want to accurately identify small objects close to you you might be better off with a visual video input, or combine both.
Using the parallax (Google it) from stereo vision should be much easier, and safer, to implement.
https://www.google.com/search?&q=stereo+camera+depth+estimation
(for some other hints, also try searching for: stereo camera depth)
I seem to recall that a few years ago there were some gaming/VR devices on the market that used that approach. (Microsoft maybe?)
Cheers,
Tom
Likes DaveE
Would that be a pricey project? I assume not portable everywhere a person goes?
Everything is more pricey than you would like.
I think you must search and review the literature available.
It seems you are rendering virtual objects into or onto the visual real world.
Optical LIDAR may be more applicable to that task because you do not want to see through walls.
What would you like to happen when you encounter a glass wall, a thin curtain, or a mirror.
Likes DaveE
I think the seeing through walls is not straight forward is it? Small walls made from non conducting materials maybe yes, but normal reinforced concrete or thick masonry walls or walls with metal in them would a radar really see through them?
If wifi passes through the wall, then where is the problem?
It will depend on the wavelength of the wifi and the number of antennas. Wifi frequencies are still rising. The wavelengths available are now significantly shorter than the holes in reinforcing mesh.
One bright point reflector, moving on the other side of the wall, should be sufficient to characterise the wall as a fixed array of scaterers. It should then be possible to deconvolve the reflections from the other side of the wall, creating a 3D image. It would still be possible without the bright point, but it would take longer to establish the matrix.
FAQ: Can Radar Technology See Through Walls and Accurately Detect 3D Shapes?
What is radar technology?
Radar technology is a system that uses radio waves to detect and track objects in the air, on land, or at sea. It works by transmitting high-frequency radio waves and then receiving the reflected waves from objects in its path.
How does radar imaging work?
Radar imaging works by using radio waves to create an image of an object or a landscape. The radar system transmits a pulse of radio waves and then measures the time it takes for the waves to bounce back. This information is then processed to create an image of the object or landscape.
What are the applications of radar technology?
Radar technology has a wide range of applications, including air traffic control, weather forecasting, military defense, and navigation. It is also used in automotive safety systems, ground-penetrating radar for archaeology and geology, and in medical imaging.
How has radar technology evolved over time?
Radar technology has evolved significantly since its invention in the early 20th century. It has become more accurate, efficient, and versatile, with advancements in digital signal processing, antenna design, and data processing. It has also become smaller and more affordable, allowing for its use in various industries and consumer products.
What are the limitations of radar technology?
Radar technology has some limitations, such as its inability to detect objects that are too small or too far away. It can also be affected by weather conditions, such as heavy rain or fog. Additionally, radar waves can be blocked by physical barriers, making it challenging to detect objects behind them. However, with advancements in technology, these limitations are continuously being overcome.
9K
26K
