Radial and Tangential Acceleration
In summary, the homework statement says that at the start of the motion, the transverse component of the acceleration of a particle is zero.
Faiq
348
2 A particle P of mass mkg moves on an arc of a circle with centre O and radius a metres. At time t = 0
the particle is at the point A. At time t seconds, angle POA = sin^2 2t.
Find
(i) the value of t when the transverse component of the acceleration of P is first equal to zero
The answer is [tex] \frac{d^2\theta}{dt^2} = 0 [/tex]
Isn't d^2theta/dt^2 equal to radial acceleration. Since angular velocity is rate of change of theta, thus rate of change of change of theta should be angular acceleration aka radial acceleration?
Then why are the equating it as transverse component?
If P goes around in a circle, the velocity vector is always at right angles to the radius through P. So the radial and transverse acceleration are equal.
In the next part, we are supposed to calculate radial force and transverse force and the answer is 3ma and 4ma respectively. If they are both equal then the force due to their acceleration should be same as well
The radial acceleration is ##v^2/a##, where v is the instantaneous tangential velocity. When they are talking about transverse acceleration, it think they mean tangential acceleration.
I went through a post on a different website which acquired the following relation. Is it correct?
[tex]\frac{d}{dt}v=r\frac{d}{dt}\omega[/tex]
[tex]a_t=ra_r[/tex]
[tex]a_t=ra_r[/tex]
The first equation is correct. The second isn't.
Why? I don't see anything wrong with the equation?
What!? Since when is ##a_r=\frac{d\omega}{dt}##?
##a_r## is the conventional symbol for radial acceleration. The conventional symbol for angular acceleration is ##\alpha##. If you are going to use unconventional symbols, you need to make that clear.
Is there a difference between radial, angular and centripetal acceleration for a circular motion? In our class, we used them interchangeably
Faiq said:
Is there a difference between them? In our class, we used them interchangeably
Let me understand this correctly: In your class, they think that radial acceleration is the same thing as angular acceleration? Actually, they are entirely different quantities. The correct equation for radial acceleration is ##a_r=\omega ^2r## and angular acceleration is ##\alpha=\frac{d\omega}{dt}##. They don't even have the same units.
So
radial acceleration = centripetal acceleration
but
angular acceleration = tangential acceleration / radius.
Faiq said:
So
but
For.a circular arc, yes.
Okay thank you
Related to Radial and Tangential Acceleration
1. What is the difference between radial and tangential acceleration?
Radial acceleration refers to the change in direction of an object's velocity, while tangential acceleration refers to the change in magnitude (speed) of an object's velocity. In other words, radial acceleration causes an object to turn or curve, while tangential acceleration causes an object to speed up or slow down.
2. How are radial and tangential acceleration related to circular motion?
In circular motion, an object is constantly changing direction, which means it is experiencing radial acceleration. This acceleration is always directed towards the center of the circle. Tangential acceleration, on the other hand, is present when the speed of the object is changing, such as when it is speeding up or slowing down while moving in a circle.
3. How do you calculate radial and tangential acceleration?
Radial acceleration can be calculated using the formula ar = v2 / r, where v is the velocity of the object and r is the radius of the circle. Tangential acceleration can be calculated using the formula at = ac = vt / t, where vt is the tangential velocity and t is the time taken for the speed to change.
4. What is the relationship between radial and tangential acceleration in uniform circular motion?
In uniform circular motion, the speed and direction of the object remain constant. This means that the tangential acceleration is zero, as there is no change in speed. However, the object is still experiencing radial acceleration, as it is constantly changing direction while moving in a circle. This radial acceleration is also known as centripetal acceleration.
5. How do radial and tangential acceleration affect an object in circular motion?
Radial acceleration causes an object to constantly change direction, which is necessary for circular motion. Without this acceleration, the object would move in a straight line. Tangential acceleration, on the other hand, affects the speed of the object. If the tangential acceleration is positive, the object will speed up, and if it is negative, the object will slow down. Together, these accelerations allow an object to move in a circular path at a constant speed.
