Btraquai
- 1
Carefully study the following plot of electric field E in N/C versus distance r in m and answer the questions that follow. The electric field is directed radially outward, and the variation of E with r is independent of direction. [/b]
For each statement, select "True" or "False".[/b]
The work done by you to bring a point negative charge from infinity to A is positive.[/b]
The Electric field falls off as 1/r for r greater than R.[/b]
The force on a negative charge placed at A points radially towards the origin.[/b]
All points at a given distance 'd' from the origin are at the same electrostatic potential.[/b]
The above electric field could be that due to a negatively charged spherical shell.[/b]
The electric potential is constant for r less than R. [/b]
Va-Vb=∫Edl
E=Kq/r^2
First i figured that since the electric field is point outward the the charge must be positive to accelerate positive charges outward.[/b]
Therefore the work to bring a negative charge from infinity to the origin would be positive the force is "pulling the negative charge in towards the origin.[/b]
It sure looks like the graph has a 1/r curve after r > R.[/b]
If the electric field points outward then a negative charge would accelerate inward. therefore the force on the negative charge is inward.[/b]
I thought about the equi-potential line at 'd' the voltage should be the same at any point at the same distance away from the charge.[/b]
The electric field could not be due to a negative charge, If it were the E-Field would point in instead of out.[/b]
Since electric field is the derivative of Electric Potential and the E-Field is zero for the given range the potential must be constant.
Where am i going astray here? I was given the hint: "Remember that the Electric Field is the negative spatial derivative of the potential. Look up the definition of electric potential and work done against an electric field. "
