Radial Proper Dist. Objects Free Fall: Calculating Δs
In summary, the proper distance between two shells in Schwarzschild spacetime can be calculated using the metric with ##dt=0## and ##d\Phi=0##, which yields the value of ##\Delta s## as a function of the r-coordinates of the shells. This can be found in a reference with the formula for this calculation. However, for free-falling objects, the proper distance cannot be calculated using the same method as the shells, as the objects are in motion and the surfaces of constant Schwarzschild time are not the same as the objects' surfaces of constant time. Instead, the expansion scalar can be used to calculate the rate of change of distance with respect to proper time, giving a different quantitative answer
timmdeeg
282
If we consider 2 shells in Schwarzschild spacetime their radial proper distance ##d s^2 = \frac{1}{1-\frac{r_s}{r}}d r^2## follows from the metric with ##dt=0## and ##d\Phi=0##. Integrating yields ##\Delta s## as a function of the r-coordinates of the shells. A reference with the formula for this is available, if of interest.
In contrast to the separation of the shells the radial proper distance between objects in free fall is increasing (accelerated, if I see it correctly). But how would we calculate ##\Delta s## in this case? Naively I was tempted to say the same way, but am not sure at all. So any help is appreciated.
Yes.
You have to do the same calculation multiple times, each time corresponding to a different Schwarzschild coordinate time ##t##. For each calculation you use the ##r## coordinates of the two objects at that time ##t##.
In other words, the calculation for the shells only has to be done once because the shells are static--they stay at the same ##r## for all times ##t##. But the calculation itself is done at a single time ##t##, so as long as you meet that condition you can do it for non-static objects as well.
Likes timmdeeg
It is also worth noting, by the way, that doing the calculation as I described it in my last post--using the ##r## coordinates of the two objects at the same Schwarzschild coordinate time ##t##--is not the only possible way to do it. It just happens to be the easiest if you've already done the calculation for the static shells. But the surfaces of constant Schwarzschild time ##t## are not the ones that the two free-falling objects would treat as "surfaces of constant time" locally; if you want to use the latter surfaces as your definition of "at the same time" (so you can calculate the distance between the objects at a given "time" according to the objects themselves), the calculation gets more complicated and will give a different quantitative answer (although qualitatively it is still the same, the proper distance is still increasing with time).
PeterDonis said:
But the surfaces of constant Schwarzschild time ##t## are not the ones that the two free-falling objects would treat as "surfaces of constant time" locally; if you want to use the latter surfaces as your definition of "at the same time" (so you can calculate the distance between the objects at a given "time" according to the objects themselves), the calculation gets more complicated and will give a different quantitative answer.
Here I have a problem. If the proper distance between the free-falling objects depends on my choice of the time, constant Schwarzschild time or sloppy the object time, then the definition of their proper distance seems to be not invariant or at least ambiguous. How would you define "a given "time" according to the objects themselves"?
That's correct, it is. See below.
For the case of the shells, since they are at rest relative to each other and to the hole, the proper distance as calculated in Schwarzschild coordinates turns out to be the right definition of this. But for the free-falling case there is no single "time" according to the objects themselves, since they are not at rest relative to each other.
There is an invariant that captures the fact that the free-falling objects are diverging, but it's somewhat technical. It's called the expansion scalar. For the case of the shells, this scalar is zero (which it should be because the objects are at rest relative to each other). For the case of the free-falling objects, it's positive, which indicates that they are diverging. This scalar's physical interpretation is, heuristically, the rate of change with respect to the closest thing you can define to "time according to the objects themselves", of the closest thing you can define to "distance according to the objects themselves", when the objects aren't at rest relative to each other.
Yes, in contrast to the FRW-model, where one can define a surface of simultaneity according to ##a(t)##. It seems, the decisive difference is that here comoving observers see themselves redshifted symmetrically.
Thanks for this hint. Wikipedia https://en.wikipedia.org/wiki/Congruence_(general_relativity) says:
"the expansion scalar represents the fractional rate at which the volume of a small initially spherical cloud of test particles changes with respect to proper time of the particle at the center of the cloud".
Would this applied to Schwarzschild spacetime mean that the expansion scalar is represented by the relative acceleration of the free-fall objects with respect to the proper time of said particle (the volume makes no sense, because its constant here)?
So in principle one could calculate the proper distance between the two objects in free-fall according to the two methods you explained assuming the same r-coordinates in both cases and would obtain different results. In both cases ##\Delta s## would be increasingly larger than ##\Delta r## closer and closer to the black hole. However approaching the event horizon ##ds/dr## goes to infinity in the shell scenario, where by I'm not sure about the ratio ##\Delta s/\Delta r## here. Does eventually the close-to-the horizon behaviour allow to prefer one of the two methods?
The underlying difference is that the FRW model has uniform density everywhere and is homogeneous, whereas Schwarzschild spacetime describes a vacuum region which is not homogeneous (the radial direction is different from the tangential directions).
Not quite. The Wikipedia page example uses a small ball of test particles, which includes particles separated tangentially as well as particles separated radially. See below.
Yes, because the spacetime curvature in the Schwarzschild vacuum region is just Weyl curvature, and Weyl curvature is volume-preserving. So, as above, a small ball of test particles will stretch radially, but squeeze tangentially, and the two effects on the volume cancel out so the volume doesn't change, and the expansion scalar of the ball as a whole is zero.
But if you just look at particles separated radially, the expansion scalar restricted to just those particles (i.e., to a radial "slice" through the small ball) is positive. (I might be making a minor abuse of terminology in calling this an "expansion scalar".) And if you just look at particles separated tangentially, then the expansion scalar restricted to just those particles is negative. Heuristically, the sum of the two is the expansion scalar of the whole ball of test particles, and is zero since the radial stretch and the tangential squeeze cancel.
Likes timmdeeg
Thanks, your explanations have been very helpful.
Related to Radial Proper Dist. Objects Free Fall: Calculating Δs
1. How do I calculate the radial proper distance for an object in free fall?
The radial proper distance for an object in free fall can be calculated using the formula Δs = √(r12 - r22), where r1 is the initial distance of the object and r2 is the final distance of the object.
2. What is the significance of calculating the radial proper distance?
The radial proper distance is a measure of the distance an object would travel if it were to fall freely, without any outside forces acting on it. It is an important concept in understanding the laws of gravity and motion.
3. Can the radial proper distance be negative?
No, the radial proper distance cannot be negative. It is a measure of distance and therefore can only have positive values.
4. How does the radial proper distance differ from the actual distance traveled by the object?
The radial proper distance takes into account the curvature of space-time caused by gravity, while the actual distance traveled only considers the physical distance between two points. This means that the radial proper distance may be longer or shorter than the actual distance traveled.
5. Is the calculation of radial proper distance affected by the mass or size of the object?
Yes, the calculation of radial proper distance is affected by the mass and size of the object. Objects with larger masses will have a greater effect on the curvature of space-time, resulting in a larger radial proper distance. Similarly, objects with larger sizes may also have a greater radial proper distance due to their larger surface area.
