Radial vs circumferential thermal stress
In summary, in this scenario, the radial stresses are likely to dominate over the circumferential stresses.
anlafuente
Hi there
I was wondering if someone could give me some insight on the following question.
Suppose you have a radially asymmetric heat flux in the outer surface of a pipe. The inner surface is cooled. This will give you two temperature gradients; one across the pipe thickness and one along the circumference. Assume you adjust parameters so that both gradients are the same. Which stresses will dominate, those due to the radial gradient (across thickness) or those due to the circumferential gradient (from front to back of the tube).
I want to say that the formers will dominate but don't quite find a physical explanation for it.
Any ideas?
Thanks
in advance!In this case, the radial stresses will likely dominate due to the fact that a pipe is usually designed to be much stronger in the radial direction than in the circumferential direction. This is because the radial stresses are more likely to cause buckling or failure of the pipe than the circumferential stresses. The radial stresses will also be higher due to the fact that the temperature gradient will be larger across the thickness of the pipe than it will be along the circumference.
Related to Radial vs circumferential thermal stress
What is the difference between radial and circumferential thermal stress?
Radial thermal stress is the stress that occurs in a material when there is a difference in temperature between the center and the outer surface. Circumferential thermal stress, on the other hand, is the stress that occurs when there is a difference in temperature around the circumference of a material.
Which type of thermal stress is more common in engineering applications?
Circumferential thermal stress is more commonly encountered in engineering applications, as it is often caused by temperature changes in a material due to external factors such as heat transfer or thermal expansion.
How do radial and circumferential thermal stress affect the properties of a material?
Both types of thermal stress can cause a material to deform, which can lead to changes in its mechanical properties such as strength, stiffness, and ductility. In extreme cases, thermal stress can also cause a material to crack or fail.
Can radial and circumferential thermal stress be mitigated?
Yes, thermal stress can be mitigated through various methods such as controlling the temperature gradient in a material, using materials with lower coefficients of thermal expansion, or implementing stress-relieving techniques such as annealing.
How does the shape and size of a material affect the occurrence of radial and circumferential thermal stress?
The shape and size of a material can greatly influence the distribution of thermal stress. For example, a cylindrical shape is more prone to circumferential thermal stress, while a spherical shape is more susceptible to radial thermal stress. Additionally, larger materials are more likely to experience thermal stress due to the increased surface area for heat transfer.
  • Mechanical Engineering
29K
